oh my GOD another cam selection thread!!!
Old 06-17-2007, 02:02 AM
Kamin's Avatar
Default oh my GOD another cam selection thread!!!
mine is a little different than most tho car is a track only drift car (think road racing). i do NOT want to flycut.
engine is a 00 ls1 w/ls6 mani. i basically live at WOT and in the 4000+ rpm range so "power under the curve" is also important to me rather than just peak. my goal would be 400whp on an aggressive tune but 375ish on a solid, reliable tune. the flatter my powerband the better. i dont need 500whp to do what i do. ****, 400 is overkill.
oh yea, i want a great aggressive choppy idle too. its a nissan with a chevy v8 so it should sound like a racecar
im thinking the torquer V2 or the MS3 should get me there no problem.
opinions? suggestions?
thanks
Old 06-17-2007, 02:04 AM
razorclaw99's Avatar
ms3..
Old 06-17-2007, 08:35 PM
chae's Avatar
I am in the same boat as you. I will most likely be going magic stick 3. You may also want to check out the torquer v3 or the xs 233/239 (from Texas Speed also). Here are some specs all nice and sorted:
- Texas Speed Torquer v2 - 232/234 - .595/.598 - 112 LSA
- Texas Speed Torquer v3 - 231/234 - .643"/.598" - 112 LSA
- Texas Speed XS Series - 233/239 - .595"/.603" - 112 LSA
- Texas Speed Magic Stick v3 - 237/242 - .603/.609" - 112 LSA
Check out this thread here:
https://ls1tech.com/forums/generation-iii-internal-engine/731216-texas-speed-prc-5-3l-stage-2-5-heads-what-cam.html#post7235926
I am also considering the stage 2.5 5.3L heads because they can be had for only $1200 and will put you at about 450+ hp/tq at the rear wheels !
Old 06-18-2007, 12:20 AM
Kamin's Avatar
Im gonna call TS sometime in the next couple weeks as soon as im ready to order the cam and see what they have to say, but i dont think i need heads for the relatively "low" power goals i have. 500whp in my car is pointless. **** a 400whp high strung 4cyl is pointless in the car for what i do, now im gonna have a WAY better powerband and torque on demand? **** lol i appreciate the opinions tho
Old 06-19-2007, 06:03 PM
Kamin's Avatar
anyone else with ideas or suggestions?
Old 06-19-2007, 06:09 PM
LS1 Tech Administrator
Patrick G's Avatar
No disrespect to the MS3, but it's a high rpm cam, not a mid-range, area under the curve cam. Think smaller duration and narrower LSA for this. Low 230s or high 220s for duration around 110 or 111 LSA with about 4 degrees of advance ground in. You need big mid-range torque for the drifting.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 06-20-2007, 01:37 AM
Kamin's Avatar
see thats an awesome answer, exactly what i was looking for! thank you!
Old 06-20-2007, 06:09 PM
ChrisUlrich's Avatar
Yo that dude Pat knows his **** too dude... I read his posts all the time.
Old 06-21-2007, 02:33 PM
Kamin's Avatar
ok so going off your new information, how about these
texas speed 228R - 228/228 .588/.588 112lsa (off the shelf, im sure i can have a custom grind down to 110)
Texas speed torquer v2 - 232/234 .595/.598 112lsa
Thunder Racing TR230/224-11 - 230/224 .575/.563 111 LSA
all of those should be more of a midrange cam, but still make peak power. just have a flat powerband. also near 400whp with bolt ons, correct?
Old 06-21-2007, 02:59 PM
delsold's Avatar
thats because its from PAT...im pretty sure somewhere in translation Patrick is roman for "god of cams."
Old 06-21-2007, 03:08 PM
Stang's Bane's Avatar
You also have the option of having a custom cam ground for YOUR needs. No need to run a off the shelf cam. Your car should be a little lighter than the average f-body and everything from gear ratio to exhaust setup and everything in between can effect the optimum cam for you.
Old 06-21-2007, 04:00 PM
LS1rulz's Avatar
You got it before I found this thread. That's funny that anyone would look at the MS3 and consider it good in the midrange. It's a killer top end cam. But top end is all it has.
I agree on the lower cams. What intake do you have? I keep thinking you'd be great with durations around 232/228 or something like that.
Old 06-21-2007, 04:30 PM
Kamin's Avatar
having a virturally UNLIMITED selection of cams is totally foreign to me. my last engine, i basically has 5 choices on cams. thats it. so having hundreds is overwhelming lol. also, midrange usually sacrificed peak power so a flat powerband doesnt exist either haha.
intake or intake manifold? intake is gonna be a 90 degree elbow to 3.5" tube, about 2 feet long to open element filter AEM dry flow 9" long filter. using an ls6 intake manifold.
Old 06-21-2007, 04:42 PM
PREDATOR-Z's Avatar
224/224 .609/.600 111+4 (Comp Cam custom grind)
That one will do the trick
Old 06-21-2007, 05:55 PM
lastcall190's Avatar
Pat G or Predator will not steer you wrong, I'd have something custom ground for your application if I were you... the cam I have has nice under curve mid range. I have the sheet somewhere on my fquick page if you look, I also posted a thread here somewhere. Good luck.
-J
Old 06-22-2007, 07:49 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
I likey....
-no need for amonster cam in something like what you are doing.
Old 06-22-2007, 08:02 AM
Originally Posted by silver-mod-o
I likey....
That is DAMN close to what I have in my car, and I absolutely love it... and my car is a fat pig compared to what car your cam is going in
-J
Old 06-22-2007, 08:18 AM
Custm2500's #1 Fan
I have a 224/227 custom grind in my #4500 truck and it runs GREAT.... I think a high lift 224 /224 would actually be better for me though.... I got the split duration for the bottle.
Old 06-22-2007, 09:56 AM
gts500's Avatar
i think for drift and track racing u need somthin that keep ur power always in the mid to high and good accelerate from low rpms specially when shifting or around tight corners u can consider reverse split cams as a good choise and remember BIGGER doesnt mean BETTER.
Old 06-22-2007, 11:29 AM
Kamin's Avatar
-J
went and found it on your fquick, hope you dont mind me posting it.
thats damn perfect for what im looking for.
