Moore Performance valve spring tool!Anyone use it?
I'm going to order a valve spring tool soon to swap out the old 918 springs for some new 918s and came across the Moore Performance tool and wanted to know if it is any better than the standard clamp spring compressor? It looks nice to me and looks like it would be alot easier but i have not tried one and did not want to order it and find out that it was not what i exspected? Let me know what you think!
Re: Moore Performance valve spring tool!Anyone use it?
There was quite a bit of debate about this very suject about 10 days ago. It got mixed reviews.
Do a search!
Do a search!
its good, but does the same thing as a 15 dollar valve spring tool just depends how lazy you are i guess.
My experience was horrible with it. It was made of a **** poor tooling aluminum and didn't work as advertised. Search w/in the past two weeks on the internal section for the tool I use and it works the best of all. It only cost $15 too!
It would be so much better if it was made of tool steel or chromoly, or the craftsman tool stull (think its chromevanadium or something like that) But tools shouldnt be mader from aluminum regardless
We've been using at our shop for quite awhile now but only on changing from stock to the 918's. Not sure how it would work on the double spring or spring with a higher rate. So far we had no problems with it and it cut time by about half an hour or maybe more once we use it more often.
Dan
Dan
Scott, put in a BIG cam while your at it.
How many people have used that tool on installing the rev double springs on stock heads? I just ant to know if it works or not.
I've got a brand new More Performance tool that they sent me under warranty. I'll let it go for $110 shipped.
