TR230 people come on in
Old 07-29-2007, 11:32 AM
98dropta's Avatar
Default TR230 people come on in
i just put the TR230 cam in my car and have noticed an idle issue
it idles fine but when you rev it up a little after you let off the gas the rpms drop and the car tries to die but finally catches up and starts idleing fine again.......
should i of drilled the TB?
what could be the cause of this?
thanks
nate
Old 07-29-2007, 11:53 AM
ws6_bandit's Avatar
Your car is doing this because it is untuned. What kind of TB do you have? If its a stock TB you can drill it but i wouldnt....that just me. A tune will straighten it up for you.
Old 07-29-2007, 11:55 AM
John02Hawk's Avatar
Maybe you need to get it tuned and raise the idle?
Old 07-29-2007, 11:58 AM
outkast6991's Avatar
my car has the same cam and the same idle issue. it's been tuned extensively and still does it from time to time. my car is an a-4 with a pretty big verter though. tuner tried on atleast 6 or 7 occasions but just can't nail it down. he did make it better at least
Old 07-29-2007, 12:07 PM
gts500's Avatar
its still tuning issue with less vacum try to drill the TB and retun the car
Old 07-29-2007, 12:13 PM
98dropta's Avatar
it has a mail order tune from pcmamerica........it idles at around 1000k
you think maybe i have a vacuum leak?
it does surge a bit will driving in first gear too
my car is a M6 too
thanks for the help so far
nate
Old 07-29-2007, 03:04 PM
Phil'sC5vette's Avatar
if your tuner tells you he's going to drill a hole in your throttle body blade, find a qualified tuner.
Old 07-31-2007, 04:07 PM
gillbot's Avatar
Cracking the throttle blade doesn't always work. Sometimes you HAVE to drill a hole.
Old 07-31-2007, 04:46 PM
2QUIK4U's Avatar
You need to get a better tune. Each car is different and therefore they respond differently. A mail order tune can get in the ballpark but not exact. I have the same cam and used to have the same issues until I got a good tune.
Old 07-31-2007, 09:09 PM
Blk97WS6's Avatar
Mine always idled fine at around 900rpms. The only time it would jump around a bit was with the A/C on which is going to happen with most cams. I have to agree with the others, and say you need a better tune.
Old 07-31-2007, 09:40 PM
Super Hulk Smash
JakeFusion's Avatar
TR230 is too small to be drilling the throttle-body. I realize a bigger cams need more air and more fuel, but the overlap is so low for that cam, that it shouldn't be required.
Find a better tuner. Most good tuners can get 240+ duration cams and 17+ degrees of overlap to idle on a MAF tune without drilling a hole.
Old 08-01-2007, 04:19 PM
gillbot's Avatar
Tell that to my IAC motor. It was 100% open and still surging. I opened the TB hole a bit and now it purs like a kitten.
