oil pump problem
Old 08-06-2007, 07:38 PM
ls1f-body's Avatar
Default oil pump problem
i just got a new ls6 oil pump from thunder racing along with my new cam and springs, the box was a little messed up but i was not to worried about it but than when i got it open the box the oil pump was in was real messed up so i took the pump out and the cover had surface rust on it and so did the smaller gear inside the pump when i took the cover off the back of the cover also had surface rust. i do not think the pump is damaged but i dont know wether to use it or send it back let me know what you think
Old 08-06-2007, 08:14 PM
BES Stroked Nova's Avatar
i would put some oil on it and try to rub off most of the rust if you can... i had the same thing on one of my installs, and 10k miles later the pump is still good...
post some pics if you can.
Old 08-06-2007, 08:15 PM
Prerun4fun13's Avatar
Send that crap back ASAP! You paid for new parts not rusted parts lol I would be furious if it was me. So IMO sent it back, the oil pump is vital!
Old 08-06-2007, 08:22 PM
i forgot to say that i did send the first one back, and the second came with less rust than the first.... so i dont know. its bullshit thats for sure.
Old 08-06-2007, 08:25 PM
Were did you order yours??
Old 08-06-2007, 08:59 PM
PureWS6's Avatar
I would send the second one back and then order a new one from some place else!
Old 08-06-2007, 09:01 PM
i am pretty sure he ordered it from speed inc. its nothing to do with speed inc, its all GM.
Old 08-06-2007, 11:24 PM
ls1f-body's Avatar
i got it from thunder racing as the ported and shimed ls6 oil pump i think i will put some oil on it and take a fine meatel brush to it and if it does not come off realy easly i am going to send it back but the problem is the engine is on a dead line and i need to finish. i am going to call thow and ask if it is normal for thunder to send out rusty parts. it does **** me off but it sounds like it might be a frequent problem witch realy makes me mad.
Old 08-06-2007, 11:39 PM
oh yours was ported? he ordered just the ls6 pump... but still things should not be rusty damnit!!
Old 07-23-2008, 09:25 AM
ZL1Killa's Avatar
well I JUST got a ls6 pump and it had rust on the inside "ring" , just surface rust but rust is rust to me
does anyone know if the melling or other oil pumps HAVE rust? i'm about to send this one back and get a refund and order one of those even though it is pricier
Old 07-23-2008, 02:05 PM
Shawn MacAnanny's Avatar
I got my ported LPE high volume pump from LPE, not even a hit of rust. I would have been skeptical if i found rust on the heart of my engine.
