how much nos can this bottom end handle
i would like to spray my car so how much nitrous can my bottom end handle? its a 383 with eagle 4.0" crank, 4340 eagle 6.125 h beam rods with mahle coated -4cc dished forged pistons with mahle plasma moly pistons rings. so how much can it handle?
1 Post
With the Mahle pistons...150 max! Mahle pistons are made out of 4032 forged alum, which is high silicon. Diamond, je, wiseco, and ross are 2618 forged alum, and can hold more heat and take more abuse. If your going to get the Mahle pistons, make sure your tune is spot on!
1 Post
Originally Posted by brad8266
150 max, We hit stock pistons with 200 shots, lol.
Tune better be spot on no matter what piston he uses. Improper fueling/spark will destroy any piston.
You are the nitrous god
try these threads...
https://ls1tech.com/forums/nitrous-oxide/551332-everything-nitrous-related-stock-bottom-end-wiring-everything.html
https://ls1tech.com/forums/removed-locked-thread-graveyard/458352-nitrous-faq-s-nitrous-push-systems-merged.html
and this forum section...
https://ls1tech.com/forums/nitrous-oxide-10/
all have lots of great nitrous related info
seeing you have a forged bottom end. I am assuming the used all the h series bearings. if so I wouldn't go any further than a 200. and w/ the diamond pistons I would say you can push it to 300
