What cam for AFR 205's?..
I have been thinking about this for awhile...First off...
RWHP goal = 460+
RWTQ goal = 420+
Compression = 11.25-11.3 with a DCR something above 8.5
Mods = All supporting bolt ons...Ported fast 90/90 combo, EWP, YT's, ETC...
I do not want to mill the heads past 62CC due to P to V clearances...
I do not want to flycut nor install valve relief pistons...
Should I go with something like a 228-232 600 112 or
a little larger cam like the MS3?..
I know with the larger cam will maybe yield more top-end power but the under the curve power will lack a little...
Overall I want to hit low 11's(maybe high 10's) on motor and 10's on the N2O...The car is not a daily driver...
Kev
RWHP goal = 460+
RWTQ goal = 420+
Kev
RWHP goal = 460+
RWTQ goal = 420+
Kev
RWHP goal = 460+
RWTQ goal = 420+
Kev
Originally Posted by cws T/A
copy this setup
https://ls1tech.com/forums/showthrea...=580073&page=1
I have been in touch with Tony(Very helpful person BTW)..He obviously recommends his cam or somethin similiar of that...I guess I have the big cam bug...LOL...If you know what I mean...
If I were to mill the heads to say 61CC chambers, with a cometic .040 head gasket, do you think I would have to run a mix, of race gas and 91...
Thanks...
Kev
Does anybody know what Tony's exact set-up was, back when he had his 346?..I know the cam was the 224/228 114+1 but what were his heads milled down to, and did he flycut?..Thanks
Kev
Kev
Originally Posted by 02TransAm/Batmobile
238/242 .605/.610 lift, 112 +3
This cam made 509/485 I believe with almost the same supporting mods - Ported 90/90, AFR 205's.
thats killer power
If done on a 346Cid NA, I want to learn from this set-up....
Christian
231/240, .643/.608 112+4 LSA (Predator custom cam grind)
61cc mill, .040 Cometic gasket, degree the cam, centered geometry, proper preload, ported Mamofied 90/90 and all the other goodies and extensive tuning. 475+rwhp or I'm not Predator.
No doubt in my mind that this set-up is producing easily 475+RWHP!!!!!
I am questioning about the second number 02TransAm/Batmobile is adding in his thread which "seems to be the torque".....509/485
Any suggestion on it????
Christian
Originally Posted by JPH
234/238 .609/.598 112+3 will do the job perfect. have used this cam before and has made 457hp/419trq thru a moser 12 blot w/4.10's with your combo.
Originally Posted by miami993c297
Hi PREDATOR-Z,
Christian
Christian
Here is another exemple.
https://ls1tech.com/forums/generation-iii-internal-engine/778335-thanks-predator-z.html
Look how high the trq is and this is A4, 3600 stall with LTs and duals.
