PEOPLE WITH 228R AND AFR's
can someone please post what they did to maximize this cam using AFR heads, I am about to buy them tomorrow and need to know what I should do to them for optimal performance.
the Cam is a 228R from TSP. other mods are in my signature. Basically the block has forged pistons and rods.
please be specific as possible. the engine is at the machine shop right now waiting for the heads...
thanks in advance.
David
ps. I am also ordering a powerbond pulley.
thanks in advance.
David
LS1 Tech Administrator
Shoot for at least an 11.0:1 static compression ratio. On 93 octane, you can actually run up to 12.0:1 if you want. Consider having the AFRs milled to give you a 62cc combustion chamber (.024" mill) and run a .040" head gasket. This will give you around 11.3:1 SCR. If you must run the stock MLS gasket, then consider milling the heads down to 61cc (.030" mill). This will give you an 11.07:1 SCR.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Patrick, I already have a set of the stock gm 6.0 gaskets, does that mean that I will have to mill the heads 0.030"? whill I have plenty of room for the PV to be safe? I dont want to go and buy a whole new set up, I just want to tweak this setup for best performance. The patriots were unmilled and they performed OK at 400 rwhp/400 rwtq, SQR did the tuning.
what numbers should I expect with this additions? the cam will be degreed as well.
should I ask for the cam to be installed in a certain way as far as degrees are concerned?
thanks for all your help and the rapid response.
David
David
At 61cc with the MLS gaskets, you will still have adequate P to V clearance running the 228R cam. I can't stress how important the milling is for top performance.
Edit, I just noticed your signature said FORGED shortblock. I would expect that you have 2cc valve reliefs cut in your pistons already. If that's the case, then you will need to mill even further to get those 2cc back.
__________________
ok patrick, What I am going to do is wait, I do have the 2cc valve reliefs. what I am going to do is order the AFR's unmilled and then have the machine shop do the milling on the heads once we know how far the pistons stick out and all the other pertinent information. can I PM you if I have anymore questions for this setup?
thanks
David
thanks
David
patrick:
Why is the milling more important than the placeent of the ivc??
Is there an advantage to gaining compression by one or the other??
No additonal squish is gained, so why is milling more beneficial?
Ive had the 228R on a 114 in the car for about a year. I have all the bolt ons.
I milled my AFR heads .020 off and use stock GM gaskets to be just under 11:01 compression. Im actually at 10.85:01. I did not want to be over 11:01 in case I moved to a hot area with 91 Oct.
I actually put down about 10 RWHP more than a friend of mine with same year vette, same cam but on a 112, and his heads milled to 59CC. When we used the same dyno on the same day about 20 minutes apart.
He just bolted on a FAST 90/90 and today we jumped on our car side by side, and he was pulling away from me. I have a 90/90 in the garage waiting to go on.
thanks
David
thanks
David
