Should i replace my lifters?
Old 09-18-2007, 11:10 PM
PunkNPonys's Avatar
Default Should i replace my lifters?
Well i am thinking about stepping up and ordering a bigger cam (MS4,MS3,F14,etc) for the weekend warrior and i was just wondering if i should take the time to replace my lifters. The only reason why i am considering it is because i have a brand new set sitting in my room. I had bought them for when i did my head swap but i changed my plans. But i really dont want to pull the heads right now but if its going to save my motor then i will. I am about to hit 80,000 miles on my car so i am pretty sure i should replace them but i wanted to get ya'lls opinion first. Thanks in advance.
Old 09-18-2007, 11:15 PM
SLP4CamaroSS's Avatar
im glad i did my stock cam on oone of the lobes was half way gone i didnt know until i pulled the cam and see the lifter
Old 09-18-2007, 11:19 PM
blueeyeddevil141's Avatar
I am tearing my motor apart for cam swap and swapping out my 120k lifters. I'll take a lot of pics of how nasty this is gunna look hah. 120k of pure beat down.
Old 09-18-2007, 11:29 PM
allthrotle's Avatar
When I changed my heads and cam I went with new lifters. Why not replace them its cheap insurance saves you from replacing the old ones if they go bad. I put in some ls7 lifters and everythings golden.
Old 09-19-2007, 01:53 AM
Blk97WS6's Avatar
If you already have them, id go ahead and do it as well.
Old 09-19-2007, 05:37 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Are they comp r's or just the 875-16's? Make sure they are setup right if you decide to. It may be a smart move to do it. You already have them. The only thing that I would not look forward to is taking the heads off. But that is just me.
Old 09-19-2007, 07:16 AM
Closed Sponsor Account
ERIK@MASPORT's Avatar
Yeah, make sure if they are an aftermarket lifter, that you set preload correctly (like the comp r's).
I purchased some GM LS7 replacement lifters when I took my motor apart. They are very nice, and can withstand whatever you throw at them on the street
I spin to 7200 and never worry with my lifters, or anything else for that matter.
Good luck!
Erik
Old 09-19-2007, 01:38 PM
PunkNPonys's Avatar
Yea i know i should do it but i am not looking foward to it. I bought the Comp OE replacement lifters. Do i need to set preload or anything or can i just install them?
Old 09-19-2007, 02:36 PM
NOBR8KSS's Avatar
I'm not planning on replacing mine unless I see excessive wear on the stock cam.
