Please advise me 408 problems
Old 09-23-2007, 01:45 PM
mohammed_k81's Avatar
Default Please advise me 408 problems
I had a problem when we tightened the rocker it would stay up because the Pushrod are to long so I changed them from 7.400 to 7.200 now the problem is the car starts perfectly but all you can hear is the rockers chic chic chic.
Now what they told me was to replace the stock rocker with an aftermarket rocker or go for a cam that I can use Pushrod 7.400
Am really confused I don’t want to speed money with out solving the problem.
I really appreciate your help what do you recommend me?
This is my engine spec
408 Strocker crank Lunati 4.000 Rods 6.125Lunati pistons 4.030 Mahle Dished Piston Set: 4.030".927" Wrist Pins, 1.105" CH, -12cc Dish
Cam comp SI7 238/244 605/612 – 110
Patriot Performance LS6 5.7L Stage II Head Assy
(2.02/1.60/59cc)
Old 09-23-2007, 08:47 PM
cam75w/ls1's Avatar
I've seen some of the guys use .010 shims on some of their applications under the rockers. Maybe if you put the 7.4 back in and use the shims you'll come out with 7.3?? I'm just guessing here. I don't know how much the heads are milled.
Old 09-23-2007, 08:54 PM
the_merv's Avatar
Those Heads have to be shaved a good bit..mine are milled .025, and I'm using 7.4" Rods with no problems..
Old 09-23-2007, 11:58 PM
Thule's Avatar
sorry about the OT but can you use the 59cc heads with 400cid+?
Old 09-24-2007, 08:42 AM
this is a video http://www.youtube.com/watch?v=kU3YI9tz0U4
Old 09-24-2007, 09:50 AM
ShiznityZ28's Avatar
What rockers are you using. AN easy way to check pushrod length with a stock rocker is to ...
Put the rocker on a lobe thats on the base circle(not open) then tighten it until the rocker does not have any play left to right and you cannot turn the pushrod. do this by hand with a socket but no rachet. then tq it to 22ftlbs counting the rotation. you want 3/4 to 1 1/2 turns on OE lifters.
7.4 sounds to long and 7.2 is way short. Its gona end up 7.3 to 7.35 more than likely. do not run a car unless it has the right pushrods you will beat up the valve train.
Old 09-24-2007, 10:45 AM
Thank you for the info my friend ill do that
Old 09-24-2007, 11:32 AM
Am usind the stock ls1 rockers whats strange is a few are tight and some are not. i hope i solve it soon
Old 09-24-2007, 11:41 AM
If they do not all come out the same while on the base curcle than the valves are beat up. all 8 exh should be the same and all 8 intake the same sometimes int to exh is diff depending on the cam core and lobe family.
Old 09-24-2007, 05:18 PM
cam75w/ls1's Avatar
Sounds like you need to check the stem heigth on your valves.
Old 09-25-2007, 07:34 AM
Well guys I really appreciate all you trying to help me solve problem my noise problem.
I have changed the Cam and now am using rods 7.450 tomorrow I will dyno tune it.
I will get some video clips.
All you guys are really grate for taking the time explaining what could be the issue
Respect
