big cam guys - how long do you let it warm up?
Old 10-03-2007, 08:37 AM
nomorews6's Avatar
Default big cam guys - how long do you let it warm up?
I have noticed a problem when i start it up, drive it a short distance, shut it down and start it up again, it has a very difficult time. I have since decided to let it warm up for a full minute and it is seeming to do fine. I have a TRaK cam. What do you guys do? What happens if you don't let it idle? During this time, it goes from 1100rpm down to about 900 rpm.
Old 10-03-2007, 09:14 AM
Steel Chicken's Avatar
its needs more tuning love.
Old 10-03-2007, 11:19 AM
Prerun4fun13's Avatar
You probably need to get it tuned again, my car starts up just fine hot or cold. I let it idle for a minute while i adjust the heater and such in the morning then i go. But i never shift over 2K when its cold.
Old 10-03-2007, 11:22 AM
Jon5212's Avatar
I always let mine warm up for about 2-3 minutes in the morning
Old 10-03-2007, 11:32 AM
vettenuts's Avatar
It is likely dumping fuel in the oil if you are struggling that much, either get an oil analysis or re-tune.
Old 10-03-2007, 11:59 AM
nomorews6's Avatar
when you say dumping fuel in the oil, what do you mean? that sounds serious!
Old 10-06-2007, 12:41 AM
nomorews6's Avatar
I just spoke with Thunder Racing - they said this was normal, and the car needs to warm up before being shut down and started up again
Old 10-06-2007, 12:56 AM
Phil'sC5vette's Avatar
I dont think it normal. get a better tune. It makes a world of differance
Old 10-06-2007, 07:26 AM
santiago's Avatar
i always let it warm up till it hits 180
Old 10-06-2007, 10:24 AM
PREDATOR-Z's Avatar
To combat this issue I lean out idle to 16>17 AFR, much less unburned fuel, no issue with oil contamination.
Old 10-06-2007, 10:33 AM
99FormulaM6's Avatar
i let me car warm up to atleast 150 before I drive off..and I dont really get on it until I see the oil temp has reached about 170 or so...
Old 10-06-2007, 12:11 PM
99Hawk262's Avatar
My car tells me when it's ready to go . I let it warm up until the idle smooths out and then I keep it below 2500 until it reaches operating temp.
Old 10-06-2007, 07:11 PM
SmallTires's Avatar
I let mine idle for about 30 seconds to let the oil get to where it needs to. Then drive it gently till is gets up to operating temperature. But as far as hard starting, that sounds more like a tuning issue.
Old 10-06-2007, 07:28 PM
Zger's Avatar
Usually about 10 minutes. I like to make sure that the oil gets up to temperature before rev'ing it past idle. I don't like to drive with a cold engine, it's hard on valve springs and my comp 921s aren't cheap. No sense wearing them out for no reason.
Old 10-06-2007, 07:43 PM
Mr. Luos's Avatar
I like to let it warm up a little when I can.
Some early mornings though, I don't want to **** off the neighbors or wake the baby, so I just leave and keep it under 2,000RPM's. Needs a little tune help yet, I get some good surging when real cold.
Old 10-06-2007, 11:28 PM
99blancoSS's Avatar
All depends on the air temperature outside. If it's 80+ I wait like 30 seconds for it to smooth out after initial start then go. Colder temps I wait for a few minutes before going. Car never has an issue re-starting though, sounds like as the others have said needs tuning.
Old 10-07-2007, 02:12 PM
INMY01TA's Avatar
I start mine and go. 231/236 here. Keep the rpms under 2500 till warm.
Old 10-07-2007, 03:58 PM
HottLS1Z's Avatar
MS3 here I try to let it run for a min or so during summer if its fall or cooler out I let it warm up until my idle drops to 900.
Old 10-07-2007, 05:33 PM
99DWPTA's Avatar
start it get situated get some music goin and drive slow till se gets warm-when COLD out-shell be started and warmed up for atleast 5 mins before it goes anywhere
Old 10-07-2007, 06:05 PM
NC98Z's Avatar
Thats easy. When the frost melts off the windshield its safe to drive. I worry more about not running it at operating temp before shutting it off. I've been known to idle in the parking lot a work in the winter 5 mins or so before shutting her down. Because I only live 7 miles from work.
Quick Reply: big cam guys - how long do you let it warm up?
