Main Studs
Old 10-17-2007, 11:05 AM
blueeyeddevil141's Avatar
Default Main Studs
Are they really much better than bolts? I am gunna be running a boosted or sprayed motor(either 13.5 psi or a 200 shot) Do i really need em?
Old 10-17-2007, 02:02 PM
Basically, can factory main studs handle 13.5 PSI fine?
Old 10-17-2007, 02:05 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
why risk it?
they are cheap insurance.
Old 10-17-2007, 02:07 PM
Because I have no money at all after you guys convinced me to splurge for the head studs!
Old 10-17-2007, 02:11 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Then wait a few weeks/months...
a 200shot is a 200 shot and stock mains can take it, but 13 psi can be 600whp or 1000whp depending on the size of the turbo and the motor.
If it where me building the motor i would do it. You might regret it later.
Old 10-17-2007, 02:47 PM
brad8266's Avatar
I have them, much better than bolts, in a high HP motor I would definitely buy them.
Old 10-17-2007, 02:57 PM
Obviously it's better...i'm just asking if there is a like....NO YOU WILL BLOW YOUR MOTOR WITH 750HP ON STOCK MAIN BOLTS situation.
Old 10-17-2007, 02:59 PM
3.4camaro's Avatar
There I said it. Go get studs. Trashing your engine because you skimped on studs will make me laugh at you. Just get 'em.
brad8266's Avatar
you could possibly
Old 10-17-2007, 03:04 PM
UGH! Now I gotta wait and order studddds, **** you guys. I am sueing all of you because you practically spend my paychecks for me.
Now I gotta wait til like next Thursday to order them or something.
Old 10-17-2007, 05:00 PM
fenix999's Avatar
im in the same situation except i know i gotta buy em.... now to come up with another few hundred for arp head and main studs
Old 10-17-2007, 10:29 PM
I have the head studs...I need the money for the main studs quick, damnit.
Old 10-17-2007, 11:02 PM
Are main studs a direct bolt in replacement..? I read somewhere that they aren't?
Old 10-17-2007, 11:11 PM
Tom@SpeedInc's Avatar
When ever use main studs imperative the block is align honed with them
My engine builder align hones even new LS factory blocks, all your block machine work is based off the main journal.
Old 10-17-2007, 11:13 PM
So I have no choice now, I need to run the stock mains.
Old 10-22-2007, 11:47 PM
JRracing's Avatar
I got main studs for my 383 build. What the hell is a few more $$$ when building a motor like this.
Old 10-23-2007, 12:28 AM
it's a few bucks I do not have! I already am down like $3,000 ahha.
Old 10-23-2007, 12:55 AM
LSInnovations's Avatar
Ive seen dozens of 9-10 second motors on stock main bolts with no issues...
