using arp bolts in rods
as far as i'm concerned ive had more dramas resizing rods unduly (where some apprentice f'ks em)rather than just fitting new fasteners on used but within resonable tolerance rods,yet i have had not a single failure on factory,holden,chev+ford conrods by fitting new rod bolts on existing rods right up to 8000+ rpm,i used arp too of course.
How? Its a cracked rod. You'd have to overbore and run oversized bearings. Its more likely just a BS legal disclaimer on ARPs part. Many, many, many people running just fine without disassembling the entire short block just to add rod bolts. We're not talking about press fit studs anymore.
Moderator
It's as much as a BS legal disclaimer as the Surgeon General's warning on cigarettes. There's viable research and testing done to give it plenty of merit. I did it this way, this is the way you're supposed to do it, if you want to ignore that, then you might as well never worrying about using loctite or chasing blind bolt holes. It's whatever the installer is comfortable with, but I sleep better knowing it was done correctly in the engines I built.
Restricted User
Restricted User
Here's a link w/ some pictures of my rod bolt install. PITFA!!!
https://ls1tech.com/forums/showthrea...=803239&page=2
