Stock ls6 zo6 heads and ? cam....
Old 11-04-2007, 10:35 PM
freaksho48l's Avatar
Default Stock ls6 zo6 heads and ? cam....
I have a 2000 ls1 camaro. Purchased a set of 243's off a ls6 zo6 vette. What would be the largest cam i could go with without having to fly cut the pistons. I also read in another post that the valves are longer from 241's to 243's so is that going to cause me to use a different length pushrod? Im looking for 420rwhp with ls6 intake and longtubes. Any info is helpful.
Old 11-05-2007, 11:50 AM
JPH
JPH's Avatar
228/232 .600/.600 112+4 is all the bigger i would put in it.
Old 11-05-2007, 12:06 PM
PREDATOR-Z's Avatar
To answer YOUR question, T-REX from Thunder, but as JPH mentionned this is not the best cam to put in.
To enjoy that cam, you'll need a heavy duty clutch, a stronger differential with 410 gears (or higher), ported TB.
I agree about his cam choice, but a TR230/224 on a 111 will be even better cam only.
Or a custom grind like:
230/228 .612/.588 110-1 LSA
Old 11-07-2007, 07:55 PM
I already have an ls6 intake, Pacesetter LT's, Custom 3"to 3.5" y dumped, volant CAI, and ported TB and MAF. When dynoed as is made 349rwhp. I want it to be driveable but its not a daily driver so big is good i just don't want to have to worry about piston to valve clearence. So a trex would clear with stock 243 heads?
Old 11-07-2007, 10:18 PM
Evans752's Avatar
The thing you need to know is the 2001 243 heads had different lenth valve in them than the 2002 and up was a little longer and I dont remember what the extra lenth was and were sodium filled.
Old 11-07-2007, 10:39 PM
03Sssnake's Avatar
Are there any caveats to using a reverse split cam? I am in the same boat, I found some 243 castings local, and very cheap. I am now looking for a cam, but I don't want to sacrifice the drive ability of my car. However, I don't want to regret picking a cam that is too small either...
