think i should hit 400?
Restricted User
You have all the exact same mods as me but I have an M6 and 4:10s. I made 400hp even and 374tq. With your A4, you may make a little bit less. BTW, with my cutout open I made 7 more hp than through the magnaflow.
How can you guys make any judgement on this? You do not even know the LSA/ICL of the cam.
With the size alone you should, but tuning has a lot to do with it.
I spec a smaller cam that put 404rwhp 385 trq on a 4000 stall, 9inch A4, cam only + bolt ons, so yeah it should make over that amount (400) properly setup.
You should be making another 10>15rwhp with that cam, unless the only bolt ons you have are headers and exhaust.
i have like your exact setup cept my cam is bigger (233/239 from TSP), but i also have stock intake and throttle body, and i have a loud mouth one witch is pretty free flowing but a cutout might make a few more ponies... Id say 385 i made 374 in 75 degrees, But also it depends on whether its 40 degrees outside... However dont worry about numbers.... i went a 12.04 and my car still shortshifts so its a very high 11 sec car. Put it this way would u rather make 400 rwhp and run low 12's or 385 and run high 11's, dont worry so much about the dyno number.
like everyone tells me, just see what it does at the track. but if your like me, i am still taking my car to the dyno saturday just to see what kind of numbers i am making. with that size of stall i am going to say that you will be just under the 400 mark. just a guess
