Daily Driver Cam
Old 12-08-2007, 12:56 AM
crapyboy750's Avatar
Default Daily Driver Cam
What DD cam are yall using that doesn't hurt your gas mileage too bad but still sounds MEAN?
Old 12-08-2007, 01:46 AM
MJD
MJD's Avatar
It's not my daily driver but I would have no drivability issues if I did. Handles city traffic just fine even with the air on. 222/228 .551/.551 115.
Old 12-08-2007, 02:04 AM
2QUIK4U's Avatar
I would go with a 224/224 .581/.581 or if you want a little more the Vengeance VRX3 226/228 .585/.588 I have seen really good results from both and they are both very streetable for a daily driver.
Old 12-08-2007, 06:56 AM
PREDATOR-Z's Avatar
Stay in the 224 cam range
Old 12-08-2007, 08:44 AM
sroach20's Avatar
if you go 224/224 112 it would sound mean, especially with the lts.
Old 12-08-2007, 10:46 AM
3rdgentug's Avatar
as stated go w/ a 224... proven performer w/ stock cubes
Old 12-08-2007, 11:53 AM
red_ryderSS's Avatar
i dd my 228/228, replacing the loudmouth for true duals in the next couple weeks. should sound
Old 12-08-2007, 11:57 AM
sroach20's Avatar
and how in the hell do you only have 22,000 miles on your car?
Old 12-09-2007, 03:33 AM
camaroguy26's Avatar
I've got the speed inc SI007 reverse split 228/222 .588 lift 113lsa (I hope those are right, it's been a while since I've looked at the specs) has a small lope to the idle but still drives great. Very rarely though the idle will search and it won't cruise under 25mph you gotta keep working the clutch. probably mostly from my tune since it was mail order.
Old 12-09-2007, 07:45 AM
Moderator
davered00ss's Avatar
Tr224.
Old 12-09-2007, 09:56 AM
Ragtop 99's Avatar
216/220 113 113 will not hurt your mileage too badly. Have it idle at 650 - 700 rpm and it will sound mean.
Old 12-09-2007, 11:32 AM
JustAFooL's Avatar
I would also stay in the 224 range. I went with a 224/230 on a 114. Suprisingly, it has a very good sound to it, especially if the cutout is open. Puts down good numbers and even though its not a dd, I wouldnt be afraid to get in it and take off.
