can some one tell me why this firebird wont start**vid inside**
what is this noise i can hear and what is causing it not to start up?
http://videos.streetfire.net/video/c...030011fdf7.htm
Cam timing off, possible bent valves, wrong pushrod length.
What was your piston to valve clearance? And how did you check it?
How did you check pushrod length?
These questions usually go unanswered/get ignored for a reason, hopefully for your sake you can answer them.
its the same exact 408 as in my car and my car fired up.
we have -8cc pistons p to v isnt an issue
we have 7.35 pushrods as recommended from the the guys who spec'd this cam
how can u have no spark when the car backfired? sounds like the timing is off due to backfire. did you do anything to the motor since the swap? its not likely the coil pack connectors got mixed up but you might want to check it anyway
For the ignition relay problem, switch your fan#2 relay to where the ignition relay goes. If it fires then, then it's your ignition relay. I had mine go south when I left my battery connected while I ported my throttle body. When I went to start it up, I was pissed. I'd also check the grounds on the back of the head, well for that matter, check them all.
we swapped out the fan relay to the ignition...nothing
The spark plug has to be grounded.If you just put a spark plug in the end of a wire and hold it in the air it will not fire at all. The spark plug is ground when it is tightened into the head. You need to either put the plug on a ground point or use a spark plug test to see if you actually have spark. By the sound of your motor. I would say that your timing is off or your pushrods are the wrong length. Hope this help a bit.
