Do I have Rod Bolt Ferrules?
Old 12-19-2007, 11:26 AM
LS1C5Vette's Avatar
Default Do I have Rod Bolt Ferrules?
I just got done searching for 1.5 hrs and could not really find a answer, hopefully someine out there know if my (built in may of 2000) vette has these ferrules? Also I do have 853 heads...Thanks
Old 12-19-2007, 06:32 PM
Tainted's Avatar
no, you dont
Old 12-19-2007, 08:24 PM
jay_lt4's Avatar
either way they just yank out when you pull out the rod bolt,, just install the new ones as they come packaged
Old 12-19-2007, 10:43 PM
LS1C5Vette's Avatar
Good to know, anyone have a write up on a vette?
Old 12-19-2007, 10:48 PM
Tainted's Avatar
i dont think anyone really has a good write up for the f-body or the vette, but its obvious what needs to be done.
Old 12-20-2007, 09:57 AM
john563's Avatar
Look in the stickies. There you use to be a write up on rod bolt install.I think Pat G condensed them into 1 write up,but anyway I recall someone in that thread stating that in mid 2002 they put ferrules in,so you may have them. Also Im pm you.I have ?? about your cam
Old 12-20-2007, 01:33 PM
Speed Kills's Avatar
Yeah, I STILL haven't found a straight answer on what has ferrules and what doesn't. I was told my LQ4 was not supposed to have them, but did.
Either way, if the bolt snugs back up when you loosen it all the way, put a pair of vice grips on the head of the rod bolt and pull. It comes out fairly easy.
Old 12-20-2007, 06:00 PM
BES Stroked Nova's Avatar
^^^ what he said cuz i did it to his motor!! lol
still no answer to what has them, and what dont...
Old 12-20-2007, 06:21 PM
Greg_E's Avatar
My 2000 LS1 had them. As was mentioned previously, they can be easily removed.
Also had the 853 heads. The 853 is cast into the head on the left end of the head, just below where the valve cover sits.
