FORGED 347 for N2O WHAT DO I NEED AND WHERE DO I GET IT
Old 12-22-2007, 12:47 AM
assassinz28's Avatar
Arrow FORGED 347 for N2O WHAT DO I NEED AND WHERE DO I GET IT
I am curious if I just want to build a 347 forged for n2o where can i get the parts and what brand do you reccommend also can I use the stock crank and also are the 98 ls1 block reliable for a 200-250 shot with all forged internals I will have a local machine shop put it together please make a list of everything that i need and where can i get it thanks.
Old 12-22-2007, 09:30 AM
TheLS1Kid's Avatar
Stock crank along with a 98 block will be fine. Make sure you get some ARP or Katech rod bolts for piece of mind.
You will need pistons with a 3.905" bore.
Check out our sponsors. Texas speed and Thunder Racing are a good place to start.
Old 12-22-2007, 11:01 AM
rickyracer25's Avatar
just know at tsp you can get a short block 347 starting at 2799 that's prob cheaper then build it your self as I have found out.
Old 12-22-2007, 11:04 AM
Black Plague's Avatar
Manley H beams and Weisco nitrous pistons katech rod bolts IMO!
Old 12-22-2007, 11:56 AM
Hennytime's Avatar
sorry to hijack, but for a 346 using the mahle 3.898 pistons, do you not have to do any machining at all, just break it down and reassemble the motor in your garage?
Old 12-22-2007, 12:03 PM
chpmnsws6's Avatar
www. ebay .com
Look up LS1 pistons
piston/rod combo for 800
Old 12-22-2007, 02:52 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Debatable. If the douchebag I bought my rods from would have sent them to me I'd have a complete rotating assembly for $570.
Old 12-24-2007, 10:33 AM
what would also be some good heads to go along with that also I would run a big nitrous cam or maybe the ms4 or ms3 from what i hear they work very good with nitrous
Old 12-24-2007, 03:29 PM
bad6as's Avatar
i think some type of prc or pp ls6 style head would be a good match if your on a budget. or some afr if you have the $$
Old 12-24-2007, 04:06 PM
OWN3D BY MY PROF!
Money wise if you wait for the Patriot Predators to come out I think those would be the best option. I'm not a fan of off the shelf grinds so I'd have something ground specifically for your desires and goals.
Old 12-24-2007, 04:56 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We have plenty of 347 short-blocks in stock & on crazy end of year specials! I Bet I even have a awesome 347 short with stainless ring upgrades for huge nitrous!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-24-2007, 06:09 PM
how much nitrous will tsp shortblocks with the stailess ring upgrades will handle? with a good tune and a set of your heads
Old 12-24-2007, 06:12 PM
PICNIC_GEORGE's Avatar
If the block is in good shape you'll be alright. But yes it will at least need a hone.
Old 12-24-2007, 09:54 PM
GMmexican's Avatar
call tsp... if it were my engine i would go with a direct port 200 shot
just kiss good bye to your 10-bolt
Old 12-25-2007, 05:41 PM
that is exactly what i was thinking about the 10 bolt. I currently have nitro daves plate they say is good for up to 250 shot
