is my motor going out??
Old 12-25-2007, 10:00 AM
DMONEY06's Avatar
Default is my motor going out??
ok ive been getting this feeling like my motors ready to give out!! smoke comes out of the oil cap and it makes alot of noise and the oil pressure is at 20psi at idle i dont know if its just the unit or what but i definatly think somethings a miss!! what are the symptoms of a motor going bad?? P.S. its a 98 t/a w/92k mods in my sig
Old 12-25-2007, 12:35 PM
99mongooSS's Avatar
mine was blowing white smoke under full throttle and It would puff black smoke on startup. Then it pooped out and made a shitload of nasty noise and my oil pressure was fluttering up and down. I broke the ringland on #7 and either a cause of the ringland or caused by the ringland the rod bearing spun on #7 as well.
Old 12-25-2007, 12:52 PM
DMONEY06's Avatar
what can i do to figure out if its about to give or should i just run it till it ***** up??
Old 12-25-2007, 12:56 PM
87gnx's Avatar
92k miles isn't really that many miles for a '98.
Compression test/leak down test should tell you pretty much all you need.
Old 12-25-2007, 01:19 PM
DMONEY06's Avatar
where do they do those tests??
Old 12-25-2007, 01:26 PM
87gnx's Avatar
I do mine in my garage, but most competent auto shops should do them also.
Old 12-25-2007, 09:33 PM
Prerun4fun13's Avatar
Oil analysis????
Old 12-25-2007, 10:14 PM
Restricted User
socmguy's Avatar
dude, double check your oil pump/pickup tube/o ring/pcv system. LS1s will run over 200K even if you beat the **** out of them!
Old 12-25-2007, 11:57 PM
Jordan S.'s Avatar
Pull your spark plugs and tell us what they look like.
Not all LS1's run forever, oil analysis (this isnt a magazine), and ya if you dont want to pull your plugs you need to take it to a shop. Take it to one or someone you can really trust. Half those shops love it when people walk in and think they need a new motor, thats big money for their pockets.
Pull your plugs tell us what they look like. If one is black and wet there's your prob.I'd try 7 first.
Old 12-26-2007, 01:53 AM
DMONEY06's Avatar
ok ill prolly pull the plugs tommorow!! if they have oil on them that is a bad thing right??
what should i be looking for??
Old 12-26-2007, 12:26 PM
DMONEY06's Avatar
i pulled the plugs they all look like **** oil on the threads of some not all plugs and the first plug on the passenger side looked more black than all the other ones..
Old 12-26-2007, 05:28 PM
JedWele's Avatar
Sounds like the motor got some issues, you could do a leakdown test to confirm but sounds like the motor got hurt at some point.
Old 12-26-2007, 06:12 PM
EndlessSummer85's Avatar
I would change the oil pump (LS1's had a problem of oil pumps that just quit) and maybe look into the LS6 PCV conversion. Have you frequently been spinning up past 5000 rpm's?
check LS1howto.com for the PCV conversion, might... might be your problem.
Old 12-29-2007, 07:40 AM
jermzz's Avatar
Oil on the plugs and smoking out the cap is a good sign of blow by. Worn rings. 20 psi oil pressure also? Possible you have a problem with the sending unit, or possibly the gauge itself, but I doubt it in this situation. If you wanna check the pressure accuracy for sure, get a manual gauge and hook it up to where the oil sender goes.
How often do you check your oil?
My guess:
You developed a blowby problem due to washed rings which caused your car to start using oil. More then it did normally if you had a consumption problem to begin with. You forgot to check the oil, it got low and you spun some bearings which is whats causing your low oil pressure at idle.
Dont quote me on that, cause anything is possible. anyway, if this does happen to be the case, start looking into a rebuild.
If you're convinced this isnt the case, do a leakdown test to eliminate the rings being part of the problem and hook up a mechanical gauge to verify the oil pressure and go from there. Also, you can check to see if your car is smoking on acceleration or on deceleration. Smoking on accel indicates worn rings, smoke on decel can indicate you're getting oil seeping through your intake rocker bolts into the combustion chamber.
Good luck.
Old 12-29-2007, 12:41 PM
SOMbitch's Avatar
^^^^^^ I 2nd Jermzz.
Old 12-29-2007, 02:23 PM
8URLS2's Avatar
I thinks its ok, Mine does it in the morning, Hate those cold starts.
Old 01-03-2008, 02:23 PM
DMONEY06's Avatar
well the car is in the shop already i got new headgaskets intake gaskets piston rings and if the pistons are trashed ima order those too!!
Old 01-06-2008, 06:07 AM
RoWDyWS6's Avatar
when is it gona be ready,ned?
Old 01-06-2008, 08:40 AM
blkbird's Avatar
Might as well get some heads since youre already there....
Old 01-06-2008, 10:47 AM
MEZA TA's Avatar
LS1 Run forever!! lol I've just gone over 209,000mi yesterday...bone stock. lol
