Comp Cams XR265HR
LS1 Tech Veteran
Yes,
I've run the cam before (54-412-11) and it is an excellent cam for a daily driver. It has tremendous torque in a range (2,800 to 5,400 RPM's) where you can really use it.
Steve
Steve
A couple of blokes over here have run that stick and it produces good results in a street car.
I reckon the 54-424-11, which has higher lift would be a better choice, perhaps on a 112lsa.
Cheers,
Macca
Cheers,
Macca
LS1 Tech Veteran
A 112 or 113 LSA would make the cam pull a bit harder in the mid-range of the torque band and it would probably not have quite as much upper RPM HP. Unless you are running well ported heads, the slightly higher lift and faster ramp rate of the 54-424-11 probably won't yield much more (if any) torque/HP than the 54-412-11.
My main caution in a daily driver is not to over-cam the car. There are a number of threads on this subject by folks who have been there and regret the experience.
Steve
Steve
I have been running the XE265HR cam because it is similar to the 02 Z06 cam and I wanted to be sure I would be able to pass California’s smog test. This cam makes 390 rwhp with stock LS6 heads and QTP longtubes. I recently passed smog with flying colors and wish I had gone bigger. I intend to upgrade to the 224/230 .581/.588 114 XER273HR.
