TR 224 + milled PRC 5.3 = PTV issues?
Old 12-27-2007, 05:36 PM
Parrothead497's Avatar
Question TR 224 + milled PRC 5.3 = PTV issues?
Hey guys,
I'm getting ready to purchase my heads and was wondering if I would have any PTV clearance issues with PRC 5.3's milled to 59cc and a TR224 112LSA. Anyone running this setup? I will be using GM gaskets.
Thanks for your help
Old 12-27-2007, 05:44 PM
quick346's Avatar
I ran a 224 on a 114 with 59cc afr's with stock gaskets. I can't remeber what it was but i think it was like .090 int and .130 ex . maybe i can find it with a search but it was more than good. and that was with 1.75 rocker's
mike
Old 12-27-2007, 05:46 PM
quick346's Avatar
found it .100 int and 135 ex
hope this helps
mike
Old 12-27-2007, 06:38 PM
TVWilkes's Avatar
I see no issues at all with that combo. Call TSP, they can make work for you.
Old 12-27-2007, 09:55 PM
What kind of compression can I expect to see with this set-up?
Old 12-28-2007, 06:25 AM
BIG_MIKE2005's Avatar
I'm running a 224/.581 114 cam with a set of Bo White 5.3 heads milled .018" & a set of FelPro stock LS1 gaskets. Haven't had a single issue on mine yet.
Old 12-28-2007, 09:39 AM
So if I mill the heads to 59cc what kind of octane will I need to run? Will 93 cut it? And if I don't mill can I run something else? How much power will I lose by not milling?
Old 12-28-2007, 11:56 AM
PREDATOR-Z's Avatar
Just run that cam at 11:1 > 11.2:1 SCR
That is the best range for the TR224 cams
Old 12-28-2007, 12:39 PM
Yep, mine is sitting at 11:1 & it runs hard for a 224 cam & 5.3 heads.
Old 12-28-2007, 01:04 PM
So what do I need to do in order to get in that range? I ordered the head/cam deluxe gasket set from thunder for a 98.I assume this comes with the graphite gaskets? Therefore pushing compression up over the mls gaskets? And just to be sure here you guys are running pump gas right?
Old 12-28-2007, 01:24 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Just give us a call when your ready, I should have 59cc 5.3l heads in stock!! 59cc is a pretty popular configuration.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-28-2007, 01:39 PM
ssheets's Avatar
I'm running 5.3 heads with an F14 (232/234 .600"/.600" 112 LSA) and measured .100"/.180" (I/E) P to V clearance.
