Question on bare Dart 225s
I was looking at the great price for Dart 225s. Do these come with a valve job already done, so the valves just need to be installed?
Also, I see they use 11/32 valve guides instead of 8mm. Do my normal springs and retainers work on these slightly larger diameter valve stems?
there heads are setup to use stock LS1 parts, and yes 8mm stem is what they use also. Check there website to verify me, if you want, and you can also see there all new PRO 1 225 full cnc head version too.
One exception to "all stock parts" I found on My Dart heads were the valve spring cups require a larger hole through them.
Spec sheet from Dart? Where did You get that? All I got was 2 heads, not a single piece of paper in the boxes. Could You scan it and post it, I thought there should have been something with them, even pm'd another forum member that has Dart's asking Him where to find info., He asked Me what I wanted to know?
http://www.dartheads.com/products/ch...ro1-heads.html
You are correct about the valve guide diameter. The LS1 head has a .500 diameter and the Dart uses a .560 diameter.
I want to use my Crane 144833 spring kit with Dart 225's, but can't find a spring locater that will work.....
I no longer have a lathe either but use the one at work. Let Me know if You cant find the right cups and if Your's aren't to hard for carbide cutters I would be glad to help You out of Your situation.
I would bet You a beer that Gunnar at Patriot could fix You up with the correct cups!
To the OP Yes the bare heads have the seats prepared for valve installation, the exhaust seats from dart have the sweetest finished radius I have seen!!! Just lap them in, and sorry for the...
You can download spec sheets here:
I am looking at putting together a bare set and was wondering if the Darts use a stock length LS1 valve. Sorry for the threadjack!
Never mind. Just looked at the link to specs.
When I disassembled my Darts, the valves were stamped with a Rev part number although they are actually made by Eaton. As I remember, they were the top of the line drop forged valves according to the Rev information I found.
Prior to installing the Crane 833's, you may want to pick up some shims as well.
