Can I use higher redline?
Can anyone tell me if installing Z06 heads w/yellow springs, yella terra rockers, and chrome moly push rods on my LS1 will allow me to go up to 7k?
only go as high as your cam can go, anything higher is pointless. If stock, the 6200 is fine. If you have a mild street cam, most will peak just before or around 6000rpm, 6500rpm is nice, but not necessary.
I have my setup peaking about 5700 rpm give or take, I've played with 6500rpm redline only because without gears, it allows me to finish the 1/4 in 3rd on sluggish hot days when the engine doesn't want to rev quick.
That is power that is a huge benefit at shift recovery, and I would think it justifies a higher shift point, if not a higher redline.
