View Poll Results: What heads would you go with for a forged 346
ET Performance 215cc Cylinder Heads
0
0%
AFR LS1 205cc 66cc Chamber Cylinder Heads
21
87.50%
PRC 200cc Terminator Series Cylinder Heads
1
4.17%
Ported and Pollished LS6 head
1
4.17%
Other (state below)
1
4.17%
Voters: 24. You may not vote on this poll
Cylinder Head Comparison
Old 01-13-2008, 12:47 PM
tilly's Avatar
Default Cylinder Head Comparison
Hello,
Well I have been doing a little reading on cylinder heads and wander if any one has done back to back comparison between the heads I stated above.
Thanks for the input.
Tilly
Old 01-13-2008, 02:10 PM
BLACK2001SS's Avatar
Bang for the buck the patriot heads (ls6 stage2or 3 depending on cam ect.) look verry good on paper flow wise thats why I got them havent had a chance to take it too the track yet.
Old 01-13-2008, 02:20 PM
RZRSEDGE's Avatar
AFRs are a very proven setup given the funds.
Old 01-13-2008, 04:56 PM
FRUSTRATED T/A's Avatar
Im thinking i might have a closer look at katech for the next motor.
Old 01-13-2008, 06:58 PM
RAGENZ28's Avatar
I'd compare the airflow graphs for each head, record the numbers and see what ones average the most. Peak flow isn't the most important thing low and mid lift numbers are also important.
Old 01-13-2008, 07:02 PM
tilly's Avatar
Well lets just say there is no budget. What head would produce the most power with the cam, displacement and combustion chamber size are all the same.
Well that is not exactly fair testment. AFR are a good example of it. A larger volume intake runner is going to flow more air because the opening is bigger and thus the bigger intake running is going to flow more. And a large intake runner on a 346 does not always produce the most power.
Old 01-14-2008, 12:50 PM
Cantalope Kid's Avatar
AFR 205 in this poll...personally I say sell the LS1...go LS2 or better shortblock...get the L92 heads and tell over priced heads to blow me.
Old 01-14-2008, 05:57 PM
SOMbitch's Avatar
Not listed but trick flows perform great and they now have an as cast version. I emailed them and their flow numbers are very close to ported AFR's. They can be had for around $1800 but you have to run aftermarket roller rockers with them which puts the cost back in AFR territory. You would have better rockers though. Just a thought.
Old 01-14-2008, 07:53 PM
HEMIETR's Avatar
GM High Tech Performance had a head shootout in an issue quite some time ago. Trick Flows won the shootout. There was some speculation that the TFS were "massaged" for the test. Try and look up the article on their website.
