will this work?
will this work?
these heads-
-02 241 heads tooken off at about 20k then p n p with 2.02 manley severe duty stainless valves, manley nextek double valve springs(good to .650) retainers and locks.
-ms4 cam
will my ptv clearance work???
-ms4 cam
my ls6 heads have been milled twice, i believe .040 total, and i have no clearence issues. you can always get a little thicker gasket to be safe, but iv'e heard there are some issues if they are too thick. you can put the heads on with some clay on a piston then rotate the motor by hand remove the head and know for sure
that's pretty big. i just found this it may be helpful https://ls1tech.com/forums/showthrea...t=#post8557412
There is a post by TSP(post #14) in the following linked thread that states the average measured PTV with the MS4 is .060 on the intake side. Most folks will tell you not to run less than .080 w/o flycutting. Add to that the larger intake valve and you have less than .060.
https://ls1tech.com/forums/showthrea...hlight=ptv+ms4
You want the answer? Mock it up and check it and you'll have your straight answer. Duration will cause ptv contact before lift will.
