Max Effort "MS4 vs Vindicator"
Old 01-27-2008, 11:25 AM
01 BERGER CAMARO SS's Avatar
Default Max Effort "MS4 vs Vindicator"
Im almost finished building my car. Its basicly a track car but once and awhile I will take it out on the weekends. I have an MS3 in there right now but am looking to swap it out with an MS4 or Vindicator. Both cams put down great numbers but dont know which one better suits me. Below are the supporting mods. What do you guys think? Or should I go custom grind?
Completely forged bottom-end with TSP 5.3L stage 2.5 heads. Roll master double roller, kooks 1(7/8) w/ ory, Fast 90/90, 36lbs injectors.
Fully built 4L60E with TCI deep pan and a Yank SS4000 conveter
Moser 9" rearend with detroit tru-trac and 4:30 gears. Full Mad-Man suspention with BMR crossmember.
TNT F2 to come later on
Old 01-27-2008, 11:29 AM
eric01ss's Avatar
hit up patrick g or predator!!
Old 01-27-2008, 11:30 AM
eric01ss's Avatar
i like this one better its a 238/242 .621/610 111+3
Old 01-27-2008, 11:35 AM
LS1 Tech Administrator
Patrick G's Avatar
Both the MS4 and Vindicator use very similar valve events. The MS4 uses more aggressive LSK lobes on intake and fast XE-R lobes on the exhaust. The Vindicator uses XE-R lobes on intake and XE high lift lobes on the exhaust. 3rd party testing has shown that the Vindicator is a little more rpm friendly because it is more forgiving of the springs you choose. Both make excellent power as both have very good valve events.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-27-2008, 12:49 PM
mgcook's Avatar
Ron@Vengence will probably tell you that you'll make 10-15more hp/tq under the curve compared to a MS4
Old 01-27-2008, 01:28 PM
GOGO's Avatar
Your setup is going to scream. Keep us posted.
Old 01-27-2008, 01:53 PM
john563's Avatar
just curious what do you put down right now with you set up?
Old 01-27-2008, 02:47 PM
Asmodeus's Avatar
How about a comp cams XFI286R113?
It's a 251/256 .660/.655 on a 113.
Old 01-27-2008, 05:30 PM
Brad Hutchcraft's Avatar
listen to mgcook.... man, jump on the hate wagon all at once...
Old 01-27-2008, 05:37 PM
99mongooSS's Avatar
I like my MS4, I plan on reusing it on my forged 347. Tsp told me with my combo that ill be close to 500rwhp on motor and the right tune. But the design is there to make the power after that its in the tuners hands but it will make it a little easier with that cam IMHO.
Old 01-27-2008, 10:10 PM
Ima jump on the hate train and order a vindicator. I can wait to see this **** runn
Old 01-27-2008, 10:29 PM
BlueGoat06's Avatar
Vindicator- 240*-244*-.608”-.596” - 112* LSA +4* ICL
3730 = 289*-240*-161*-.358”-.609”
3655 = 297*-244*-160*-.351"-.597"
MS4 - 239*-242*-111* LSA
2130 = 289*-239*-164*-.384”-.649”
3731 = 291*-242*-163*-.359”-.610”
how would they fare against the HPE mega death ?
Mega Death Cam- 244*-242*-112* LSA
3732 = 293*-244*-165*-.360”-.612”
Old 01-27-2008, 11:23 PM
sidewayz28's Avatar
i agree with your choice cant wait to see results
Old 01-28-2008, 01:31 AM
james562's Avatar
hell yea can't wait to see some #'s and 12Xmph traps....
Wonder where you'd shift the Vindicator @? 6800-7200?
Old 01-28-2008, 06:01 AM
i have the vindicator as well.
Old 01-28-2008, 06:25 AM
s346k's Avatar
is it really worth the hassle and cost of a cam swap at this point? he's got an ms3, the ms4 isn't going to make much more hp, and if is considering the vindicator, why not just stop f'ing around and buy a t-rex? if you're looking for a "max effort" build, ditch the fast 90 setup and buy a vic jr, then get a custom ground cam somewhere in the 246/254 range on a 108 lsa. get a th350 with a brake and 8" converter and some 410 gears. your setup is far from a max effort build.
i'd guess all 3 of those cams you posted about will make within 10-15 whp of each other and et/mph VERY closely.
Old 01-28-2008, 07:41 AM
1Bad00SS's Avatar
+1000 .. hardly seems worth the effort.
Old 01-28-2008, 08:48 AM
Max effort can mean alot to diffrent people. The reason I want to swap it out is because I have yet to drop in the motor and besides I want to slap the MS3 in my 01 Formula just for fun. I already have everything here at my shop to do the swap so why not. The set up im running right now is just to get the car on its feet and put down good numbers and track times with a max effort streetable cam. This is my shop car and want to be able to drive it like in my orginal post. Im not going custom grind yet cause im not done getting the MAX EFFORT out of my current set up. Test and trial have alot to do with getting the max out of your ride. Racing is about getting the right combo (Engine, Trans, Suspention and tune). When the time comes I will be swapping parts out for better ones. Hell there already here laying around in my shop LOL
Old 01-28-2008, 09:08 AM
robz*'s Avatar
Old 01-28-2008, 02:38 PM
2002camaross35th's Avatar
+10000 on that one...but thats jus me being biased having a T-rex cam!
Quick Reply: Max Effort "MS4 vs Vindicator"
