ls6 cam into a 98 ss
if i swap a ls6 cam into my ss will i need to swap out my springs or will my stock springs handle the ls6 cam. the car only has 50k miles on it. please if anyone can help i need to know asap becasue i need to know if i should buy this cam.
i think its only about a 20 hp gain, but it will still drive like stock, and idle should be fine. i will tune the car anyways onec im done with hptuners. but im just looking for some cheap hp
Just put mine in 2 weeks ago, 98 ws6 a4. I was real reluctant to put it in from what i read about the power gains but the power gains with the longtubes and ls6 intake really woke up the car past 3500 rpms. You will have to change the springs but use the stock ls1 pushrods. Have not got the car dyno'd since the cam but the *** dyno says there is more there. Good luck
even if you're gonna get the cam CHEAP....why not put in something bigger?
for all the hassle and expense (gaskets) you may as well get 40hp instead of 20hp.
something mild like the 224 cam would be fantastic...and has been PROVEN to perform very well.
