Heads and Cam
Heads and Cam
Which heads will give me the most horsepower, and what would be the best cam to use with them, and i dont want something that will make my compression really high because im going to get a procharger.
Re: Heads and Cam
you could get killed asking that kind of question around here without doing a search first. ive been living on this site for the last 7 months and heres what ive learned. the cam will give you more power than the heads. it depends on how big of a cam you want. the G5X2 has been the cam everybodys been talking about. cartek, GTP and TEA ive seen make in the 440rwhp range with a tr 230 cam. if your gonna add a procharger your probably gonna want a 6.0 head to keep the compression down.
Re: Heads and Cam
sorry im new. I want to do the cam first, which one will give me the most power. and i also want a lumpy idle. can i get a cam and everything i need to install it for $600
Re: Heads and Cam
go with the G5x2, that cam is breaking records left and right. theres a guy running that cam with the bolt ons and stock heads and he rippping off high 10's, i dont know if its the same guy or not but someone with the same setup is putting out 425hp at the wheels BUT i dont know how that cam would perform with a procharger.
Re: Heads and Cam
