Heads to mate with MS3 Cam?
I am pretty sure I want to run an MS3 camshaft with Livernois Motorsport Stage 2 LS6 heads. Would there be enough clearance without having to flycut? If not what do I have to do to get them to fit. Any help would be great, thanks guys!
I would like a set that can handle the lift of the MS3 and has good flow numbers overall. I would like to stay under 2k for heads. The Livernois heads are $1300 and I have looked at some PRC heads that are around $1500. I keep seeing people saying to just go with AFR or ET but those heads are almost the cost of my entire H/C budget.
That what I was running on my GTO. I had no problems with PTV. Just give them a call tell them what cam and they will set you up. I was very happy with my heads and service from TSP
LS1Tech Premium Sponsor
We offer both the Street LS6 head & a PRC Stage 2.5 5.3l head configured for the MS3 camshaft! Both setups are dyno proven to add 40-45rwhp! Checkout both of these options: They should both be in stock & ready to ship immediately!
http://www.texas-speed.com/shop/item...d=649&catid=40
http://www.texas-speed.com/shop/item...id=84&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
If you are firm on your budget, the PRC heads are a great product for the money - not taking anything away from them.
