LQ4~~arp rod and main bolt #'s
Old 02-20-2008, 01:58 PM
ls1leadfoot's Avatar
Default LQ4~~arp rod and main bolt #'s
can anyone tell me what the part numbers are for apr bolts in a 2001 lq4 block
main bolts
head bolts
rod bolts
thanks john
Old 02-20-2008, 06:54 PM
anything?????
Old 02-20-2008, 10:32 PM
5.3LJimmy's Avatar
This should be the correct numbers. For future reference they are the same as the LS1.
Hex Head Bolts - 134-3609
Pro Series Rod Bolts - 234-6301
Main Studs - 234-5608
Old 02-21-2008, 09:14 AM
thanks man i appretiate it
the machine shop is telling me that the part numbers cant be the same because it is a 6.0 and not a 5.7 and that it is a lq4 not a ls1
thats the only reason i asked
thanks!!!
Old 03-23-2008, 01:16 AM
BAD2000TA's Avatar
thanks!!!
I'd find another machine shop then!!
Old 03-23-2008, 01:24 AM
prochargedchevyi's Avatar
thanks!!!
Um....here's what you do.
First, pimp-slap that tech in the face with your pinky ring hand, then find yourself another machine shop that has experience with Gen III's.
If they can screw that up, I wonder what else they're second-guessing?
Old 03-23-2008, 07:33 AM
forcd ind's Avatar
i have to ck the # bolts i got-when i went to replace them, the orig bolts had a ferrel in the rod cap, and the arp bolts would not fit w/o rem. them
thats when i said to hell with them and boought new rods for the new pistons, lol
mine was an lq4-would like to hear if others ran into this prob.
also, since they are "cracked rods", not sure if they can be rebuilt if needed
Old 03-23-2008, 08:35 AM
Are you referring to the stock rods? If so, yes, they can be rebuilt, but you'll need a bore gauge to check the clearances of the bearings in relation to the crank journals. I can't remember the clearance specs off the top of my head, but I know it's in the GM powerbook.
Hope this helps,
Vince
Old 03-24-2008, 08:45 AM
engine fired up friday....no probs....machine shop did a great job!!!!
Quick Reply: LQ4~~arp rod and main bolt #'s
