Sucky Day!!!
Sucky Day!!!
UPDATED!!!
Just finished putting in my new cam and heads on my 02 WS6 last night, been working on it with a friend for the past 3 days. We were so releived when we finally got her all back together....cranked her up ran her through the heat cycles...when on the second cycle we noticed it started to make a ticking sound that keep getting louder....shut her down let her set for a bit cranked her back up and no ticking sounds! We removed the valve cover to check the rockers....thinking one of them came loose, but all of the were still good. So we thought maybe some trash got into one of the lifters. Anyways drove down the road and had the exhaust welded back up and head on to work in her....we'll about five minutes into the drive around 60 mph...that DAMN TICKING sound came back.So it looks like I will be ordering new lifters for her. Sucks, cause now I have to tear the motor down to put new lifters in her! My mistake....should of done that from the get go! And it's weird sitting there just idealing no ticking,or it might be that I just can't hear it, but put her in gear and start going down the road....and DAMN TICKING!
Yea....I was told that also by another friend....it's just weird, just got back from driving the car and no taping sound. Parked the car ran the RPM's up to 2000 and it started taping noise again.
Yeah, stuff happens. But you can get a bad lifter, even in a new set.
Run a pint of marvel mystery oil in it for a few miles, then change the oil.
If you have to change the lifters, get new LS2 lifter trays, its worth the extra $20
I am going to look everything over first, cause really don't want to tear it all down again. Ron at Vengenance mentioned header gasket leak can make the same sound.
And yes oil pump was replaced with a new LS2, and the push rods should be right size....sence they all came from Vengenance as a package deal.
damn bro, that sucks we just finished putting my engine back together last night and damn I would hate to take it apart again. Mine has sort of exhaust leak in the td's at idle thats making me crazy. i thought it was something bad but its coming from the exhaust. I did replace my lifters though with ls7.
If you are at that point...spend the $107 for a new set of LS7 lifters from Scoggin Dickey....they had the best price. I was in a hurry to get my car camed I forgot to consider the lifters needing replacing. Mine looked real good when I pulled them out and put them soaking in a bucket of oil. But I have 100,000 miles on mine.
I would check the oil pump o ring first.
I have talked to Little Red camaro on this I thought about the o-ring on pump but his oil pressure is steady at 40 psi at 850 rpm idle and goes up to 70 psi at higher rpms it is the same lifter acting up each time I am stilling leaning towards a small piece of trash in lifter.
does it sound like this
http://www.youtube.com/watch?v=r0aQd_IfypU
here is the thread
https://ls1tech.com/forums/showthrea...689&highlight=
and a similar thread...
https://ls1tech.com/forums/showthrea...ng+number+part
sounds exactly like your problem did u use a new o ring or the old one...even though it looks ok you need to replace it everytime...
We'll here is the update....put new LS7 lifters in the car this weekend and no more taping sound. Not sure what caused the old ones to fail. Might have been the miles on the old ones plus bigger cam and springs! But after 12 hrs of work she is done and running great.....working on these cars suck!
Thanks everyone for your advise!
