stock rockers or yella terrs
Old 03-08-2008, 03:48 AM
Restricted User
Lawnboy's Avatar
Default stock rockers or yella terrs
what would be better
Harlen sharp rebuilt stock rockers , with better bearing
Or a set for the LS1 Yella terras
Old 03-08-2008, 06:56 AM
vettenuts's Avatar
Yella Terra rockers. Better wipe if correctly set up.
Old 03-09-2008, 08:05 PM
CalSpeedPerformance's Avatar
I think the question of which is better is obvious on which one is better...but necessary not usually
Old 03-09-2008, 08:27 PM
Restricted User
Lawnboy's Avatar
what about on procharged 347 making 700 HP
will the rebuilt stockers hold up , or would the yella terras be the smart choice
Old 03-09-2008, 08:39 PM
SOMbitch's Avatar
with that kind of motor just do the YT's and make sure the wipe is good.
Old 03-09-2008, 08:49 PM
Restricted User
Lawnboy's Avatar
whats the wipe?
Old 03-09-2008, 09:06 PM
SOMbitch's Avatar
Look here Lawnboy. http://forums.corvetteforum.com/show....php?t=1935010
Old 03-09-2008, 10:29 PM
snake charmer's Avatar
yts are the way to go my friend
Old 03-10-2008, 12:11 AM
Tom@SpeedInc's Avatar
stock rocker arms, we get the most rpm out of them.
Old 03-10-2008, 12:25 AM
Restricted User
Lawnboy's Avatar
Fraser would you recomend to have them rebuilt by harlen sharp?
Old 03-10-2008, 09:49 PM
thats fine
Old 03-10-2008, 10:24 PM
SOMbitch's Avatar
Even better than the new design YT Ultralights? Have you tried them? I know there were issues with the earlier design (mainly weight). From what I have heard the newer design places less weight over the valve tips and can handle 7000 plus rpm fine. Just reading a Pat G thread and he had his limiter set at 7200 with no valve control issues. The stockers flex a lot sacrificing lift and are not actually true rollers. I know the rebuilt HS stockers are a big improvement over stock and thats what I have probably decided to run. I appreciate your input as you have much more real life experince to draw upon than I.
Old 03-11-2008, 12:25 AM
Restricted User
Lawnboy's Avatar
OK last ?
Is it worth HS to rebuild them , i think it cost like $300 , not sure though
How much better will they be with the HS rebuild
I will only be pulling to about 6,300 - 6,500 RPMs , its a street car
Old 03-11-2008, 06:12 PM
vettenuts's Avatar
I have checked the wipe pattern on the stock rockers and the Yella Terra's. There is no comparison, especially as you start increasing lift over the stock lift. The stock rockers scrub a very wide pattern on the valve stem and are almost impossible to correct (I gave up). No question in my mind, a properly set up Yella Terra is superior to the stock rocker.
Old 03-11-2008, 06:58 PM
kwiksilverz28's Avatar
Rebuilt stockers. They are this setup and I will use them on the next motor whenever that is...
Old 03-13-2008, 01:07 PM
Some individuals have an agenda and tactics when it comes to presenting their product, the current yella terra rockers are an improvement over earlier versions.
We use the stock rocker arms on our shop car engine 7800rpm shift points and 1154rwhp
using PSI CT1225 valve springs with 160psi on the seat
stock LS7 lifters too
the shop car ran 8.60 5 days in a row on drag week and drove 1000 miles between the tracks.
Old 03-13-2008, 01:14 PM
junior28570's Avatar
Hmm .. I like nice round numbers. Thanks for the testimony to real world application Fraser. Seems like YT's MAY be better .. but stockers will work just fine for the stoutest of street cars.
Old 03-13-2008, 01:15 PM
SOMbitch's Avatar
Daaaayuuuuuuum
