Are there any torque specs for head bolts that aren't tty?
Old 03-08-2008, 04:04 PM
pwtr02ss's Avatar
Default Are there any torque specs for head bolts that aren't tty?
Also what's the torque specs on stock rod bolts?
Old 03-08-2008, 04:32 PM
Grimes's Avatar
yeah, there is a procedure and a specific torque sequence for ARP bolts. I'm sure you can find it if you search. Also, the bolts should come w/ instructions.
https://ls1tech.com/forums/showthrea...rp+torque+head
Old 03-08-2008, 04:44 PM
pwtr02ss's Avatar
There's a thousand specs for arp's. I'd just like a straight up normal spec.
Old 03-08-2008, 08:20 PM
LS1MCSS's Avatar
Another post about the same problem, with an answer.
https://ls1tech.com/forums/generation-iii-internal-engine/878572-does-any-one-have-torque-specs-arp-234-6301-rod-bolts.html
Old 03-08-2008, 09:21 PM
pwtr02ss's Avatar
What about the heads?
Old 03-09-2008, 07:21 AM
vettenuts's Avatar
No such thing. The torque specification is based on bolt material, diameter, preload requirements, etc.
Old 03-09-2008, 07:55 AM
Restricted User
socmguy's Avatar
I've ordered several sets of ARP bolts and they came with different torque spec sequences.
Old 03-09-2008, 11:03 AM
Cole Train's Avatar
idk if my ARP studs came with instructions i'm gonna have to double check~Cole~
