Where can I get a LS6 block... and is it worth it?
Some of you may have seen me post about my new set-up coming. If not... then here it is.
Absolute Speed stage 2 5.3's w/ 230/236 cam. I was wondering about getting a LS6 block.. for more power, and for future projects increasing the cubes.
Can I do it and is it worth it?
Where can I find the blocks for sale if I wanted to put it in with the heads, and what else would I need?
Sorry about the length... I have been reading, but still do not know enough!!
Thanks
Mike
Thanks
Mike
Re: Where can I get a LS6 block... and is it worth it?
there is virtually no diffrence in the blocks here. i think it's all just a casting number diffrence. they both have 346ci bottom ends and since you have an 01, the onle thing diffrent is that true LS6 shortblocks have coated side skirt pistons and a diffrent cam. no displacement diffrence at all.
I am already getting a 12 bolt.
I was told that a could build a 366 stroker with the LS6 block.
I was also told that the LS6 block would add about 10-15 rwhp to a stock cubed motor.
Is this not true?
Is this not true?
Shorty Director
All the things you could do with the LS6 block.. You could do with a LS1 block.. Who is feeding you this information? You are going to waste a lot of money listening to the person who is feeding you your current information.. Just shoot me a PM.. I'll point you in the right direction..
Senior Member
There is no difference in the blocks, not power wise anyways.
The LS6 block is a little beefier in some important places in the block, but thats about as far as it goes. Not worth doing unless you have to get another block for some reason.
I have no back to back comparison to proove this, but the ls6 block has better bay to bay breathing from the windows between the mains that was designed to cut down on windage loss and make up to 10 more hp from them alone, I will look for a gm tech report I have when i worked for GM that explains how they did this while adding more strengh to the block, the only proof i have is the 25% 02 f bodys that seem to dyno 10-15 rwhp higher with cam onlys than others, we have seen them all post here, the cars that do 415's and 425's with cams only. alot of tuners know about this and dont want to let the cat out of the bag becuase the extra power makes there product look better but I have to becuase Im the one who told mike#9 since he wanted to build a forged internal to go with his heads.
chris
Read this....
http://www.idavette.net/hib/02ls6/listpages.htm
and
http://www.c5registry.com/Documents/ls6/INDEX.HTM
Your answer lies within....
and
LS6 heads might be worth 10-15rwhp over LS1 heads in stock displacement applications.
Blocks don't make power, heads make power.
Shorty Director
This is funny.. Yes there is better bay to bay breathing. It was designed to help our cars stop burning so much oil. Now for the horsepower increase. I disagree.. Look at the 02 Z06's out there. The avg dyno is 365rwhp stock. The cam is basically almost a B1 or C1 cam.. If you look at LS1's with just cams and stock manifolds.. They dyno pretty much the same.. A friend of mines 99 WS6 with no LS6 intake and a 218 cam and stock manifolds dyno'd 380rwhp with a tune.. He had all the other bolt ons, but still had cats.. This was a 6 speed with 4.10's.. This was 2 years ago.. I also remember seeing those so called unverified at other dynos other than the tuners that so called did the tuning 425rwhp cam only cars.. Not all were LS6 blocks. This is the internet bro.. I bet half the people on here do not even have cars..
Shorty Director
Verb several in my area have dyno'd 360rwhp plus.. This is one of our local cars with just a cone air filter.. http://forums.badrap.net/thread.php?...&styleid=9
I even know that the ls6 block made more power, but you wont see the extra ponies untill you do some mods, god damn why didnt I wait a few months to buy my vette
