Stock Cam Advertised Duration?
Old 07-23-2003, 03:18 PM
BamaJohn's Avatar
Default Stock Cam Advertised Duration?
Apologies if this is easily found somewhere--I've searched for several hours. I would like to know the stock cam specs for a 2002 LS1, including advertised duration.
Old 07-23-2003, 03:21 PM
horist's Avatar
Default Re: Stock Cam Advertised Duration?
<a href="https://ls1tech.com/threads/showflat.php?Cat=&amp;Board=UBB1&amp;Number=591148 &amp;Forum=UBB1&amp;Words=what%20are%20"stock%20ca m"%20specs&amp;Match=Entire%20Phrase&amp;Searchpag e=0&amp;Limit=99&amp;Old=allposts&amp;Main=590970& amp;Search=true#Post591148" target="_blank">https://ls1tech.com/threads/showflat...=what%20are%20"stock%20cam"%20specs&amp;Match=Entire%20Phrase&am p;Searchpage=0&amp;Limit=99&amp;Old=allposts&amp;M ain=590970&amp;Search=true#Post591148</a>
Old 07-23-2003, 03:35 PM
BamaJohn's Avatar
Thanks for that, but that only shows .050" lift figures. I'm looking for the advertised duration to use in Intake-Valve-Close (IVC) event timing calculations.
Old 07-23-2003, 06:02 PM
Cal
Cal's Avatar
Add 50 degrees to those figures and you will know pretty close what advertized duration is. A better question is why do you care? The stock 2002 LS1 cam for an Fbody is a truck cam! If you have a Tahoe it has the same cam in it, nothing special here.
Old 07-23-2003, 06:34 PM
BamaJohn's Avatar
Calculating the dynamic compression of a stock 2002 LS1 might be a worthy exercise, it might not. To complete the calculation requires precisely knowing Intake Valve Close, measured from the advertised duration.
Old 07-24-2003, 01:32 AM
nuzee's Avatar
BamaJohn
Try these numbers:
IVO (BTDC) -16 IVC (ABDC) 34
EVO (BBDC) 40.5 EVC (ATDC) -13.5
ICA 115 ECA 117 LSA 116
198/207 @50
Old 07-24-2003, 06:05 PM
BamaJohn's Avatar
Many thanks!
Old 07-24-2003, 06:50 PM
WayneSS01's Avatar
uh oh what's that Argo dude up to now?
Quick Reply: Stock Cam Advertised Duration?
