What is needed for a cam install?
Old 03-18-2008, 07:00 PM
Jsak's Avatar
Default What is needed for a cam install?
Im not talking about tools but I want to know what I need to complete a successful and safe cam setup. I know I dont need titanium retainers because the biggest cam im going with is a 230 duration. I just need the mandatory things such as pushrods, valve springs, and etc. Its for a 02 ss a4.
Old 03-18-2008, 07:06 PM
transamfreak01's Avatar
how many miles are on the car? with my cam swap im doing the cam, pushrods, retainers, valve springs, double roller timing chaing and ls6 ported oil poump
Old 03-18-2008, 07:28 PM
massls1guy's Avatar
Here's a good writeup:
http://www.ls1howto.com/index.php?article=23
That topic is pretty common. If you read in this room daily you will see it discussed quite a bit. Search is also a powerful tool.
Old 03-18-2008, 07:29 PM
LS6_Silverado's Avatar
You only need to upgrade your lifters and springs, but thats the bare minimum i would upgrade my pushrods to hardened ones also. Brandon
Old 03-18-2008, 07:48 PM
Jsak's Avatar
I have 21000 miles on the car.
Old 03-18-2008, 07:59 PM
Tally TransAm's Avatar
cam, springs, pushrods, gaskets, new crank bolt, lifters are needed unless you feel like pulling the heads for no reason
and most importantly
beer
Old 03-18-2008, 08:03 PM
Bill Bowling's Avatar
I do not think you would need lifters.
Bill
Old 03-18-2008, 09:09 PM
sroach20's Avatar
from what he wrote i think he meant to say "lifters arent needed ".
Old 03-18-2008, 09:10 PM
sroach20's Avatar
springs, pushrods, and at least a 12 pack are required.
Old 03-19-2008, 09:09 AM
Jsak's Avatar
thanks a lot. Why do most places try to sell you titanium retainers if they are not needed. I think they should recommend them if your doing a big cam instead for safety purposes not for a small one.
Old 03-19-2008, 09:34 AM
sroach20's Avatar
just get some patriot duals, they are cheap and include retainers.
Old 03-19-2008, 09:49 AM
they rec titanium retainers because they are lighter
more weight + high rpms + more agressive cam = valve float
Old 03-19-2008, 10:06 AM
black01_WS6's Avatar
dual valve springs are cheap and have a lot of other benifits beside being stronger.
If you are going with a 230/xxx cam you would need dual anyhow unless you are under .600 lift. if you are close to .600 i would get them as a safety precaution.
You do not need new lifters- the stock ones are good, and untill recently most people with big or small cams would leave the stockers in.
Old 03-19-2008, 10:13 AM
yup... yeah i wouldnt really worry about the lifters with that low of miles on the car unless you have the money to spend.
Old 03-19-2008, 04:11 PM
King Nothing's Avatar
my tr230 is in my room waitin for install but i got the package from thunder racing, dual valve springs, titanium retainers, locks and seals ported oil pump and ls2 timing chain . . . course i don't have a stall yet
Old 03-19-2008, 06:10 PM
Jsak's Avatar
Ok. thanks for the help. Also have you heard about comp making a 227/xxx cam that is putting down good numbers. Where can I find it, I looked under comp and no solution.
Old 03-19-2008, 11:46 PM
silverLSWON's Avatar
if you do a oil pump swap get a new O ring and make sure it's the red one(updated o ring). people always forget that
