which cam for my M6? C-1,C-2, or TR Reverse split??
Old 07-30-2003, 09:38 AM
John98LS1's Avatar
Default which cam for my M6? C-1,C-2, or TR Reverse split??
asking for a freind on another site: looking for a good all around cam from the choices i have here (C-1,C-2 or TR 230/224 .575/.563 111 LSA reverse split). I will be running stock heads and all bolt ons. I daily drive the car and it does see the track. i will not be having gas on the car. soo if you could help me out that would be great. thank you
Old 07-30-2003, 10:11 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Default Re: which cam for my M6? C-1,C-2, or TR Reverse split??
My vote for the C1, but then again I'm biased.
You can't go wrong w/ the cams you listed, though I'd look into a single pattern TR cam, like the TR224.
Also, what find of idle quality are you looking for?
Old 07-30-2003, 10:15 AM
malibu350's Avatar
I've read in a few books that having more duration on the exhaust side can make up for the weak stock exhaust ports, by allowing more time for the exhaust gas to be released.
Old 07-30-2003, 10:16 AM
John98LS1's Avatar
well why do you say c1?? he was leaning more towards the c2, well idle quality... he doesnt want it to die on him lo. thanks
Old 07-30-2003, 10:19 AM
JRcamaroZ28's Avatar
I'm putting in a TR227/224. the exhaust on the LS1 is great if you have LT headers and a free flowing exhaust but the intake is the whole bottle neck of the system so i wanted a little more on that side to help it along some. there has been good results w/ the Reverse split. Jason99T/a dynoed I belive 400 HP to the wheels w/ stock heads,TR227/224, and 4.10's in a 12-bolt. if your gonna stay NA then mayeb think about the Reverse split. but never can go wrong w/ the TR224 single pattern.
JR
Old 07-30-2003, 10:22 AM
!LS1 11 Second Club
Why did I say C1? Look at my sig. Makes great power, is a little easier on the valvetrain (.566 vs. .581 lift), and has a decent chop.
C1 is great street/strip cam.
Either way, a tune is in order to get the most out of any of these cams, so drivabilty issues would be hammered out w/ a good tune. Lots of people have run fine w/o tunes also. It's a crapshoot (mine needed tuning). Enjoy!
Old 07-30-2003, 10:46 AM
Cal
Cal's Avatar
I would take the C1 over the C2 also because of the lift; that .581 sounds like a spring killer to me. The fact that the C2 idles a little better than the C1 even though it has more duration tells you it has some very steep ramps, another spring-killing feature. If he wants a 224 duration tell him to go with the TR224, otherwise C1 cam.
John98LS1's Avatar
soo the score so far is
c1=2
c2=0
TR Reverse split=1
keep it coming guys, thanks!!
Old 07-30-2003, 11:00 AM
KGSloan's Avatar
i'll vote for the TR reverse split.
all of the cams you listed are good cams. i went with the tr230 because i liked the horsepower it makes while still having a pretty flat torque curve (i have 350rwtq from 3200 to 5700). the car did not drive very good at all before the tune. now it drive pretty well. starts up fine cold or hot. the idle is also not that bad. it's choppy, but it dosn't ever die or surge. good luck with the setup
Old 07-30-2003, 11:04 AM
John98LS1's Avatar
c1=2
c2=0
TR Reverse split=2
thanks guys, keep the info coming!!
Old 07-30-2003, 11:05 AM
!LS1 11 Second Club
I vote for the C1 again!
Old 07-30-2003, 11:17 AM
John98LS1's Avatar
the score so far is
c1=3
c2=0
TR Reverse split=2
Old 07-30-2003, 11:18 AM
!LS1 11 Second Club
Old 07-30-2003, 11:27 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
My vote goes for the new TSP232 232/228 camshaft Here's a quick graph for ya.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-30-2003, 11:39 AM
John98LS1's Avatar
thanks, check PM's. but it dont think that was one of the cams to choose from. please stay on topic. thank you
Old 07-30-2003, 12:31 PM
BadBadZ's Avatar
My vote is C1 as well. Good torque all thru the powerband. My car is a daily driver and I have no problems with it at all. It has a nice lope to it, I have had lots of people comment on the sound even through my "quiet" Random Tech. catback.
Old 07-30-2003, 12:57 PM
mike c.'s Avatar
i also vote for the c1. i have it and it freakin rocks.
Old 07-30-2003, 01:16 PM
John98LS1's Avatar
the score so far is
c1=5
c2=0
TR Reverse split=2
dnm why none for the C2??
Old 07-30-2003, 02:11 PM
John98LS1's Avatar
ttt
Old 07-30-2003, 02:41 PM
Reboot's Avatar
I really like my C1 cam. It makes really good power as well.
