Ticking noise AHHH SH*#
So I start up my car and this ticking sound comes on. It was very pronounced upon first starting it and when it warmed up it went away a little. My GF was in the car and was asking "what is that noise". It was obviously valvetrain. What do you guys think. I haven't gotten on the car in like weeks. I have never taken the car past 5500rpm. I think a lifter is starting to fail, but who knows. I am planning on taking off the valvecovers tomorrow and go probbing around, but we'll see. Wish me luck.
So I start up my car and this ticking sound comes on. It was very pronounced upon first starting it and when it warmed up it went away a little. My GF was in the car and was asking "what is that noise". It was obviously valvetrain. What do you guys think. I haven't gotten on the car in like weeks. I have never taken the car past 5500rpm. I think a lifter is starting to fail, but who knows. I am planning on taking off the headgaskets tomorrow and go probbing around, but we'll see. Wish me luck.
It is possible the ticking noise is simply a loose spark plug wire. I had this exact issue (ticking noise) and thought the worst, but it turned out to be a loose plug wire. As this is easy to check and very cheap (free) I'd rule this out first.
Install University's Spark Plug and Wire Installation how to guide shows this in the Troble shooting section:
"After this plug install if you hear a loud ticking sound when the engine is under load then you should check your gaskets between the AIR pipe and exhaust manifold.
Also, if you hear a ticking sound all the time then you probably have a loose spark plug wire boot on the spark plug".
UKCamaroSS
but mine never did this until yesterday. when you start it up warm, it even does it. sorry, i'm not trying to steal the thread.
Piston Slap probably. My car has make a ticking noise since I bought the car. I have replaced all of the valvetrain and I still have the same ticking clattering knocking sound. I just don't worry about it. As hard as I run it sometimes that sound can't mean anything.
Aluminum heads, block= a noisy motor.
I am not saying that you shouldn't pull the valve covers and check for a broken spring and even pull the pushrods out to make sure they are straight. That would be a good thing to do from time to time. If all of that checks out don't worry about it unless the car starts to run bad or develops a miss.
I just started it up during lunch when it was dead cold. No noise at all. Maybe it was just one of those one time things. I revved it up and around a bit, and it seems perfectly fine. I have no clue what this is or was. I am still gonna check everything out.
It wouldn't go away if it was valvetrain noise guys. I have been driving one of these (piston slap) motors almost 5 years. Mine doesn't knock every cold start either. By his description it sounds just like piston slap (CSK). This website has soundclips but don't let the rest scare you. www.pistonslap.com It's pure BS.
That is exactly what mine sounds like!!!! Thank you sooo much. My dad is so pissed he wont even talk to me right now, but now I have evidence. It is just a slight piston slap. It is no where near that loud but that it what it is. We have only had the car for a little over a week now and yesterday was the first time it did it. Then, today, dead cold, it is silent. I will still check out the valvetrain but this sounds like what it is doing
