how do you eyelash a stock internal engine??
I found this during my H/C swap.. 2000 LS1, I'm the second owner, stock everything.. I bought it with 17k miles on it and all it had was a bolra CB..... I also had 6 bent pushrods that came out of this swap..The BADLY bent rod was on the driver's side.. #5 I believe..
THis lash pic is from the pass side.. And what's with the brown?? I'm used to gray or black..
ive missed 5th before i guess i better get a new cam, pr, lifters, and springs just to make sure everything is up to snuff. gotta make excuses to the wifey for the mods
Ok.. I was just thinking that people fly cut reliefs in anyway, so it'll be fine.. ^ Thanx do0d..
I'm just curious as to the piston thickness...
Oh well.. SLIGHT volume change in that cyl... I just want to get his car running.. Cam will be here on Wednesday.. Just gotta degree it and slap the engine back together.. I'd like to have it running by Thursday.. But I have to work on it after work.. and my ASP UDP is still on back order from TR..
