Threw a rod bearing, what are my options?
Old 06-01-2008, 06:46 PM
ScreaminBird99's Avatar
Default Threw a rod bearing, what are my options?
Im pretty sure i spun a rod bearing, it still drives just getting extremely loud, its holding oil pressure at about 40 psi, i dont want to lock up the motor, i have another car to drive.
Basically i need to know what kind of options will be my best cost effective bet on wat to do. Any suggestions, i appreciate your guys help.
Old 06-01-2008, 07:08 PM
coondog's Avatar
you will have to pull the motor and put a crank kit in it and replace probably at least a piston or two. samething just happened to mine. it was around $2,800.00 to repair.
Old 06-01-2008, 07:46 PM
therobman's Avatar
for 2800 you should have just forged the stock shortblock for that price
Old 06-01-2008, 08:28 PM
Intercooler2's Avatar
Is this common? I read alot of posts about spun rods so was wondering.
Old 06-01-2008, 09:14 PM
98trans-am's Avatar
its part of normal wear and tear, some motors will last longer than others unless youre really low mileage than theres really no explanation as to why it happened. i too spun a rod bearing and i just bought another stock crank and then went with probe forged pistons,perfect circle piston rings, custom comp cam, clevite bearings, arp rod,main and head bolts and other stuff such as gasket and what not. anyways all in all i paid 1700 in parts for the rotating assembly and valvetrain. although it did cost a hell of alot more with all the machining and blue printing and balancing all in all i have a pretty reliable motor and only cost about 5,000 with all assembly. the only thing i had to do is drop it back in.
Old 06-01-2008, 09:35 PM
daniel6718's Avatar
there did you throw it? you mean spun a bearing? you can remove and fix for prolly 400 in parts and machining...
find another shortblock to put in it..
Old 06-01-2008, 09:36 PM
daniel6718's Avatar
meant to say make sure its not a rocker problem first
Old 06-01-2008, 10:38 PM
99blancoSS's Avatar
Figure out whats wrong first. Thats the first thing.
Now as far as whats the best bang for the buck that will be argued. You ca have the current sb rebuilt and put some forged stuff in and be around 3k I guess, maybe little more or less depending on what you do.
My 408 short block is $4292 plus freight. Its built with Callies and Wiseco and ARP and ACL race bearings, Clevite or hell fire rings. Damn solid setup. You need to ship your engine if you dont find someone local so dont forget to add that price. Or you can find a 347 from another sponsor for less than I sell 408's for. I even sell a less expensive version for $4042 with a Scat crank.
Just something to think about.
Old 06-01-2008, 11:11 PM
landonew's Avatar
Same thing happened to me. Simple answer:
1) pull motor
2) turn crank (machine)
3) new bearings
4) new rod bolts
Thats what i did. Not as fun as forged/stroker but much more cost effective.
Old 06-01-2008, 11:25 PM
Mr CHI's Avatar
This infamous scene comes to mind after reading this thread...: "Oh ****...What the F**k was that?!?"..."Its the motor...shes thrown a rod"..."Is that serious?"...."Yap"....--Jake and Elwood Blues-The Blues Brothers
Old 06-02-2008, 07:57 AM
SOMbitch's Avatar
I love that movie
I think TSP has a forged 346 SB for under $3K.
Old 06-02-2008, 11:46 AM
5_02ls1's Avatar
hmmm threads like this make me glad i dropped that k member and spent the little extra on rod bolts....
Old 06-02-2008, 12:21 PM
s346k's Avatar
1) pull motor
3) new bearings
4) new rod bolts
i agree with this guy. it's funny how everyone on this website thinks we're made of money. "oh, you spun a bearing...you should get a 4834902 cid forged ls7 block with an f1r procharger @ 58 psi (low boost) capable of 347832 hp on pump gas. it will only cost you a fortune (they can finance too) or your first born."
i'd guess for less than $700 you could pull the motor, have the crank turned, install new bearings, rod bolts, and necessary gaskets/liquids and be on your way. just one thing - make sure you didn't circulate any bearing trash (check cam bearings, etc for wear) and get any additional metal out of the engine before reassembly and eventual starting.
Old 06-02-2008, 12:26 PM
5_02ls1's Avatar
if he did spin a bearing he will need that rod as well.....
Old 06-02-2008, 01:38 PM
99blancoSS's Avatar
Lets see you get it done for that. $700 to fix an engine that has a spun bearing. Why would anyone pay to have an engine built in the first place really, if all they can do is buy some parts and bolt them together themselves.
Because after you've wasted 3 or 4 grand and had it not work or blow up again you have to spend even more money to do what you should have done in the first place. Have it built by someone who knows what they're doing.
These aren't legos they dont just snap together. I had a shop teacher tell me once he could rebuild and engine with some vise grips and a screw driver but he wouldnt want it.
Old 06-02-2008, 01:42 PM
i was actually looking at possibly stroking it, any input on what the would run me, possibly 383? Could i use my stage 2.5 5.3 heads stil?
Old 06-02-2008, 02:00 PM
s346k's Avatar
what's your problem dude? these engines are no different than any other engine. anyone with the will can read a book, take their time, and rebuild an ls1 engine. believe it or not, gm does carry books with specs and parts stores do carry plastigage...as well as torque wrenches. everyone acts like an ls1 is a spaceship engine never before seen by man. what gives? i don't understand why 80% of the people on here like to turn a $700 fix into $3,200. yall must enjoy debt or something? i think it's hilarious. so when your boy breaks a front window on your house you are going to add a level and underground parking? must be the american way.
how much are new bearings? got a crank turned and polished for $80 last year. rod bolts - $225? last i checked, my labor is free.
Old 06-02-2008, 02:14 PM
SOMbitch's Avatar
Yes those heads will work on a 383. A friend of mine is in the high 10's N/A with PRC 5.3's on a 383.
Old 06-02-2008, 04:05 PM
99blancoSS's Avatar
A shop put this motor together not even a backyard mechanic..
https://ls1tech.com/forums/generation-iii-internal-engine/924763-super-technical-help-needed.html
I guess this person didnt read that how to be an expert book that you read.
If you think all it takes is a set of tools and a manual then go ahead and open your own shop and help the rest of us out
Old 06-02-2008, 04:13 PM
2000_SS's Avatar
OP: dude, there are a MILLION options you have here. i spun a rod bearing and my car has sat since (~3-4months now). my motor locked up completely. i parted out everything under the hood to help fund the new motor. my crank was NOT salvagable, nor was 1 rod. the rest was good. now i have a LSX block soon to be built pending the sale of my S10 and my dirtbike.
you can look at it one of two ways:
"DAMN, my motor's broke!"
or
"SWEET! I'M GETTING A BETTER ENGINE!"
do what you want with what YOUR budget will allow. debt sucks, but we all have it, just don't go stupid with it. if you have something else to drive and want to go faster, let it sit and piece together something you'll be happy with.
Quick Reply: Threw a rod bearing, what are my options?
