grinding down intake rocker bolts...
how are you guys grinding down your intake rocker bolts so they dont protrude down into the intake port...are you guys angling them or just flat grinding each of the intake bolts so wichever thread you start the bolt with (two right) either way the bolt will not protrude (hope this makes sense)...every little bit counts when it comes to max power/effort stock ls6 346 combo
I just ground down the 8 intake rocker bolts last night. Used a bench grinder and just ground the ends off just before the threads to aviod damage. Took 15 mintues...
