Possible timing chain noise
Old 07-13-2008, 12:10 PM
epox4life's Avatar
Default Possible timing chain noise
What are the chances that my timing chain is having problems at 57k miles?
I am hearing a metal scraping sound on idle, the noise follows with the rpm. This started happening a few months ago, the car has popped/backfired when cold and rpms dropping.
Can the power steering cause a metal scraping sound? I had added fluid after I noticed it was low but didn't flush the system, it is not overfilled or anything.
Please help with this on going issue, I want to get it fixed before anything happens.
Old 07-13-2008, 12:59 PM
Zitty'sZ's Avatar
Remove the serpentine belt and start the car , if you still hear the noise you will know it is not the power steering pump or any of the other accessories .
Old 07-13-2008, 05:42 PM
01ssreda4's Avatar
spun bearing????
Old 07-13-2008, 06:05 PM
epox4life's Avatar
Originally Posted by 01ssreda4
spun bearing????
I hope not, how loud of a noise do that make?
This is hard to hear unless you put your ear close to the engine or front wheels.
Old 07-22-2008, 04:15 PM
epox4life's Avatar
I took off the belt still getting the same noise. So it's not the power steering. Loose timing chain or spun bearing anything else it could be?
Almost positive it's the timing chain the noise is coming from there and it's almost like a rattling.
Old 07-23-2008, 02:34 PM
PERFECT Z28's Avatar
Take off the timimg cover and take a look...
If it is the timing chain, now would be a great time to switch to a LS2 chain or dbl roller adj, ported oil pump and aftermarket undrive pulley.
Old 07-23-2008, 06:16 PM
aaron653's Avatar
and a cam...
Old 07-25-2008, 10:52 PM
01ssreda4's Avatar
^^^^good idea there.
Old 07-27-2008, 10:08 AM
epox4life's Avatar
I think that's what I'm going to do. If I do the timing chain and oil pump but NO cam does the engine have to be dropped?
