Will I need to flycut?? help me out please
I am hearing different stories here, TEA said this will work but I just want to be sure. I am getting some TEA stage 2 LS6 heads milled to 61cc and I will be using stock MLS head gaskets, the heads have a 2.04 I valve and a 1.57 E valve, the valve drop AFTER milling will be around a .120on the intake, TEA said I will NOT have to flycut, what do you guys think, I want to be 100% sure as I do NOT want to flycut??
Are you using stock gaskets? Check the PTV and if it is bad you will need to discuss with TEA at that point. Brian is pretty sharp at this stuff so hopefully you are OK. The only question I would have is the statement "will clear" means different things to different people. To me, its 0.080" intake and 0.100" exhaust.
