96MM Typhoon intake manifold gasket
I have a 96MM typhoon intake manifold that I need to install. I have everything needed minus the intake manifold gasket
Does anyone know of any other gaskets that would fit the 96MM typhoon gasket? I called professional products and I can't find a retailer that sells their gasket for the manifold, so I'm left trying to find something else that will work.
I'll take any advice at this point
Thanks again
Thanks again
I got the intake used with all the parts - the intake manifold gasket. I called PP and was told the part # for the gasket but I'm not able to find a retailer that sells it. The guy from PP told me I would have a hard time finding it. he said, "I would need to press the issue with the retailers to make them check for the part". So far I haven't had any luck
a trick that has worked for, used it alot on lt1's or any tb that require a paper gasket, i have used the roofing felt and cut out the gasket and it has worked for me, or u can order a sheet of fiber paper from mcmaster carr and make all the gaskets u will ever need.
the roof felt, works but i prefer the thicker paper, if u dont know what roof felt is, its the tar paper used under shingles on roofs or in the walls of homes that have siding.
go to home depot and tear a piece off
jk
jk
Thanks again
Thanks again
jk
jk
They sell rolls of gasket material at most parts stores. I know Auto Zone and Advanced Auto sell the rolls. One of those rolls and some quality time with a razor blade should net you a suitable fix. Good luck!
