??? Lean Oe Rich Mixture Cause Detonation/ping???
which A/F mixture causes detonation/ping? lean or rich?
would a rich or lean mixture cause tranny issues like when i floor it at 70 it will go, kick, then go again
ya i know that the engine wouldnt cause tranny problems but just wondering if it would cause drivability issues like what i described in a previous post
like i said check fuel pressure ...a clogged filter or pump going bad will cause similar problems....if it aint getting the fuel it needs it will detonate stumble misfire blah blah blah...check the simple stuff first
my car after cam install ran lean and the transmission was feeling like it was slipping and going to fail, tuned the ve table and I was amazed to say the transmission problem is gone for ever! I think the engine was hesitating and caused the trans problem.
