Yella Terras, worth it or not?
Old 09-01-2003, 09:36 AM
SPANKY LS1's Avatar
Default Yella Terras, worth it or not?
Yella Terras, worth it or not? I have seen dynos that show 2-5 rwhp gains, are they worth it, or are stock rockers fine? Do they fit without any modifications to the heads? I would assume that they are more reliable than stock rockers, but if a stock rocker is 1.7, and a YT is a 1.7, where is more power to be gained? Or do stockers not consistently have 1.7 ratio? Do they flex at high RPMs and have, say 1.65 or something like that? Basically what are the pros and cons of the YTs, (Other than the $500 pricetag) Shawn
Old 09-01-2003, 09:40 AM
megathumpzillaX's Avatar
Default Re: Yella Terras, worth it or not?
THe 2-5hp are within the 1% variations a carefull chasis dyno will show run to run, so I'm skeptical of much hp gain.
They are stronger by a hair, stiffer, and the bearings won't break as stockers do ocassionally. The ratio is also more accurate. Plus they look nice.
Old 09-01-2003, 09:54 AM
Dave Carney's Avatar
maybe a good mod when you are done spending your money on stuff that makes you go faster....I'm not there yet myself
Old 09-01-2003, 10:02 AM
Ragtop 99's Avatar
The question for me is:
Are they better than stockers for high rpm motors with agressive cam lobes (e.g. XE-R big duration cams)?
Old 09-01-2003, 10:15 AM
KGSloan's Avatar
there has been talk about the stock rockers flexing under high loads. that's another reasone people are switching to them
Old 09-01-2003, 10:36 AM
Brian2001SS's Avatar
They are great insurance from the stock ones spewing needle bearings throughout the engine. That alone is worth the cost. Also, they tend to quiet down the valve train slightly.
Old 09-01-2003, 11:13 AM
BergerMan's Avatar
Do a search and you will find more info and opinions than you could ever want. I replaced mine to minimize stress on the valvetrain. I wanted a complete roller setup with strong rockers. I have seen 750hp LS1's with stock rockers and they run fine. Roller valvetrains were developed for a reason, less friction, less flex means more power. How much power is hard to say, but when everything works together the power will be there. I believe Speed Demon ran stock rockers on a dyno and immediately swapped to the Yella Terras and picked up 5-10. I'm not positive on the #'s but do a search and your find it.
Old 09-01-2003, 12:10 PM
Senior Member
Country Boy's Avatar
If the choice is betwen the stockers and the YTs, then the YTs are better... now for the money ~$450.. I would do the new Crane Pro Mag 1.7 rockers for the LSx. They are stronger than stock, have 5% less weight at the valve than most aluminum rockers, cromemoly steel, so they are light, lifetime warrenty againt breakage, REBUILDABLE and the best part..... adjustable!!. They also cost less than the YTs
CLICK HERE
You know where my money is going
Old 09-01-2003, 01:05 PM
GMC SKI's Avatar
Who sells those Crane Pro Mag Rockers ?
Do you have a Part number for the Ls1 1.7 rocker ?
I find this out after buying a set of YT 's ..
How much cheaper are we talking ?
Old 09-01-2003, 01:27 PM
gomer's Avatar
I didn't gain any power from my YT's.. but I feel better about whats going on under my valve covers now. And I did notice a SLIGHT decrease in valvetrain noise.
Old 09-01-2003, 01:32 PM
felton316's Avatar
Those kits are still on backorder from what I've been told. Won't ship until late sept. They are going for $498.
Old 09-01-2003, 01:42 PM
Senior Member
WOW!!! Thats $$$$. Ive found them for $430 on Ebay. Some guy has an Ebay store and sells them. I guess thats why I cant find them now
Old 09-01-2003, 01:46 PM
Senior Member
Speed Inc. has the 1.85s, but they also come in 1.7s.
Old 09-01-2003, 01:50 PM
Senior Member
<a href="http://www.compcams.com/Technical/Catalogs/106-03/308-323.pdf" target="_blank">Click me for LS1.LS6 Pro mag info </a>
Its about 1/4 way down the page
Old 09-01-2003, 01:57 PM
HumpinSS's Avatar
www.texas-speed.com has them for 10.00 cheaper but they are 1.75 instead of 1.7
Old 09-01-2003, 02:32 PM
DONAIMIAN's Avatar
If i was to change out the rockers, I would just go with a set of shaft mounts, and if was to go with a set sof shaft mounts, it would be the Comps. Theyre a lil pricey, but if you have the money to throw at em go right ahead.
Old 09-01-2003, 06:45 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
I would get the Comp's over the Yella Terra's, if you want a better rocker.
Old 09-01-2003, 06:59 PM
LS1derfull's Avatar
They are not Crane Pro magnums, they are Comps. Either YT's or comps will give more bearing reliability, but i disagree that stockers deflect or bend and give up lift.
They are of rigid design, and it would be very hard for any of these aftermarket rockers to be lighter than stockers, dont kid yourselves, just like many of the factory parts on these cars, stock is fastest, lightest. Example:oem driveshaft, 10 bolt rear,stock pushrods,connecting rods.There is advantages to light duty OEM parts, just some risk involved in keeping them around when you make good
power.
Old 09-01-2003, 08:30 PM
Senior Member
power.
Whoops... typo
You can trust all the stock parts you want, but check out the GREAT reliability!! Stock 10 bolt... Stock hydrolics.... lets not forget about those great stock rockers that like to spew pretty needle bearing in your motor
