What timing set is this??
http://i51.photobucket.com/albums/f3...100_2905-2.jpg
This was pulled out of my car today, but I have no idea what timing set this is.
My first guess was the Cloyes,... but the Cloyes' crank sprocket is different.
It says "Hex-A-Just" on it... and the numbers read 8-02 174DA.
There was also a Rolon timing chain installed if that helps.
I need to know so I can sell it.
Thanks!
Thanks!
The crankshaft sprocket is one solid piece, and only has one keyway groove.... so it really isnt 'adjustable'. Is the stock crankshaft sprocket that way? Do you think they used the Cloyes cam sprocket, but reused the stock crankshaft sprocket?
