'04 lq4?
Old 09-06-2008, 08:04 PM
1fast bird's Avatar
Default '04 lq4?
I'm looking to get valve springs for my lq4.Apparently there's a difference between '03 and'04.I'm not sure if I have an '04 or not.That's what the guy said that I bought it from.How can I tell the difference?
Old 09-06-2008, 08:08 PM
12secSS's Avatar
They are the same physical size and shape from 1997 to current. Are you looking for stock replacement or aftermarket? For stock replacement I would recommend the Yellow Spring found on LS6, LS2 engines. For aftermarket it depends on the lift of the chosen cam.
Old 09-06-2008, 08:10 PM
69LT1Bird's Avatar
Who told you the springs are different. They are the same.
1fast bird's Avatar
I'm doing a turbo build and want springs good to .650 lift.I noticed there are springs up to '03 and some for '04 on.
Old 09-06-2008, 08:14 PM
Summerwolf's Avatar
there are lots of options, sounds like it is time to talk to a sponsor.
Old 09-06-2008, 08:27 PM
1fast bird's Avatar
Sorry ,I must be an idiot.What is the difference between an '03 and an '04?I noticed that the head studs are different.I don't know why I was thinking springs.Long day!
Old 09-07-2008, 01:25 AM
12secSS's Avatar
Just that, GM wised up and change the head bolts from two differewnt lengths to one standard length. No more short length bolts on the ends.
Old 09-07-2008, 11:48 AM
Hi-Po's Avatar
I have the Yellow Springs installed and really wish I could get more out of them. I would opt for a dual spring, they are alittle pricey but well worth it.
Old 09-08-2008, 02:43 PM
1fast bird's Avatar
How do I know what year the block is?I want to order head studs soon and don't want the wrong ones.
Old 09-08-2008, 02:48 PM
GA95DCMSS's Avatar
Not to thread jack, but I have one out of an 05 yukon in my 1995 Impala and remember hearing something about GM switching to one-piece valve spring seats/ valve stem seals. Does anyone have any information on this?
Old 09-08-2008, 02:59 PM
12secSS's Avatar
Chances are you have the equal length head bolts. I would double check the length, do you have the heads on it currently? If so simply remove them and see, if not then you will need to use a spare bolt to measure the engagement depth.
In 1999 GM switched to a one piece valve seat and seal.
Old 09-08-2008, 03:11 PM
GA95DCMSS's Avatar
Do you know of anyone having any problems with these and aftermarket springs?
Old 09-08-2008, 03:23 PM
69LT1Bird's Avatar
Just treat it like a normal LS1.
Quick Reply: '04 lq4?
