LSXRT test ?
The intake is the only way I can run a 102mm tb without buying new heads or a sheetmetal intake. I think the longer runners will help also.
Lsxrt
I have mine installed and test drove the truck from Medford Oregon to LA to ship the truck to Germany. I did not dyno the truck with and without the LSXRT. It was a new engine, and I just had to have the intake. I went with a 90mm LS7 TB off of a Corvette because it was ETC. It looks nice, swells and contracts when you rev the engine, and draws a crowd when you pop the hood. The engine runs very strong. My Dad did the installation, and used some of the lines from the stock injection to connect the FAST regulator to the stock fuel lines.
It looks nice, swells and contracts when you rev the engineAttachment 208903Attachment 208904
Sounds as tho this manifold needs more development......we had a
prototype crossram manifold that deflected as described due to
change in manifold vacuum.
The greatest forces are on idle when there is nearly full vacuum ~14psi (imagine a 14lb load applied to every square inch of the plenum). On full throttle, the vacuum is released and the manifold will revert to its normal shape.
Fast told me its a 38hp upgrade and is the Best Intake they currently produce for anything, the kits are available now with rails, I will have mine very soon and will be dynoing!
That CAN'T be good. If it is flexing then eventually that hard plastic will break.
After looking closer at the FAST90 I have in the shop here I cant see how this thing is flexing.. I know its taller but they would have had to really make the plastic thinner for it to flex.
Fast released a 102 mm LSR manifold for cathedral port.
http://www.lsxtv.com/forum/new-ls1-l...dral-2182.html
