My ported LS3 intake pics/info
Old 04-13-2010, 08:42 PM
LS1 BU's Avatar
Default My ported LS3 intake pics/info
Decided to port my own intake. Curious to see how much I gain. I will be testing it on back to back dyno pulls to see what it does. Will be going on 416 LS3/L92 motor. Motor make 482 rwhp with stock ls3 intake.
I spent tons of time on this thing. Porting wasn't bad. But removing the inner posts and resealing the intake is very time consuming. I have tons of open cuts hands from inside plenum. Very sharp edges in there. If I had it to do again I would just pay someone to do this. I have around 30 hours in cutting/grinding and sanding.
I opened up the runners and hand sanded them. Went about 6-8 inches deep
I opened up the throttle body area and removed all sharp edges. Finish sanded.
Removed inner posts. Resealed bottom post holes with metal plates and JB Weld. Took two packs of it.
I hand sanded plenum area to remove sharp edges.
I think It turned out ok
Old 04-17-2010, 09:10 PM
1lejohn's Avatar
Nice job. You did do alot of work. I only ported the opening on mine.
Old 04-17-2010, 09:49 PM
one fast zo6's Avatar
LOOKS GREAT! you are the man, good job.
Old 04-17-2010, 09:56 PM
SweetS10V8's Avatar
Borrowing a buddys unported intake to compare back to back?
Old 04-17-2010, 10:08 PM
SmokedOutZ28's Avatar
Nice! I'm really interested in the results.
Old 04-18-2010, 07:49 AM
spaz1's Avatar
lets see if it was worth it...
Old 04-18-2010, 08:47 AM
LS1 BU's Avatar
Thanks for compliments. I would have had results yesterday. But I broke the tailshaft housing on my trans on the second pull with stock intake. Right before I was going to install the ported intake. Should have it fixed this week.
Hoping to see at least 15 rwhp with this thing.
Old 04-18-2010, 09:14 AM
LS1 SPEED's Avatar
intake looks good
hand look bad : LOL
I'm sure it will see some gains once it's back together.
Old 04-18-2010, 10:09 PM
bww3588's Avatar
any pictures of where you cut to seperate the intake?
Old 04-19-2010, 08:12 AM
LS1 BU's Avatar
I used a small air saw to cut out the posts. I went in through the throttle body opening. Just have to me real careful. This is the underside where the post wells are sealed up.
Old 04-19-2010, 12:26 PM
bww3588's Avatar
you didnt split the intake to do any porting inside?
Old 04-19-2010, 01:21 PM
LS1 BU's Avatar
No I just reached in the T/B opening and hand sanded the plenum to remove all the sharp edges. There is alot of sharp edges in the plenum.
Old 04-19-2010, 01:37 PM
cam
cam's Avatar
If i get time I might port mine too. I was thinking about just machining out the entire hole where the bottoms of the posts are. So instead of trying to work through the TB opening ( which is impossible for me theres no way my hands can fit in there I tried ) so I thought if i just machined them out and down to the roof of the intake then i could make some plugs and either plastic weld them in there or some other suitable method. Probably be a hella lot easier.
Im curious though is there anywhere inside the air cavity in particular that responds well to porting or is it mainly the TB opening and post removing that makes gains?
Old 04-20-2010, 01:18 PM
LS1 BU's Avatar
The throttle body opening and post remove enlarges the plenum. I think that is where the added air flow will come from. I did not take any material out of the plenum floor or roof. Just knocked down all the sharp edges.
Old 04-20-2010, 01:22 PM
bww3588's Avatar
and all of this was done thru the TB opening?
Old 04-20-2010, 01:23 PM
cam
cam's Avatar
Excellent thanks! I'll post pics if I ever get to it
Old 04-20-2010, 02:22 PM
69LT1Bird's Avatar
It looks exactly like what Jeremy Formato from Fasterproms does, cuts out the posts for his stage 2 porting.
Old 04-20-2010, 02:45 PM
cam
cam's Avatar
I can get my nephew to reach in and hand sand the edges down for me. These port jobs seem to be worth the hassle in terms of gains and Im all about gains
Old 04-20-2010, 03:38 PM
Moderator
JayplaySS's Avatar
Good job man. Looks just like mine, what a PITA
Old 04-20-2010, 04:24 PM
LS1 BU's Avatar
I hear ya. Over a week later and my hands are still all sliced up from the inside of the plenum.
Quick Reply: My ported LS3 intake pics/info
